Sony KD-55XF8505 won‘t start
  • TobiasG
    • Sep 2022
    • 16
    • Deutschland
    Does anyone have the service manuel for the KD-55XF8505?
    I've already tested a few things and apparently the mainboard is defective and I don't have the exact instructions on how to find out what's defective.
    PSU and T-Con seems to work.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4538
    • Italy - Milan
    Re: Sony KD-55XF8505 won‘t start
    Better 4 you to explain all symptoms, measurements done...
    • dskall
      • Oct 2016
      • 2905
      • usa
      Wow, to have mainboard schematics. That would be awesome.
      • TobiasG
        • Sep 2022
        • 16
        • Deutschland
        When I plug in the TV, everything stays black, the status LED also stays off.
        PFC: 390V
        CN6801-2-3-4-5: 75V
        CN6401-5 (STBY3.3V): 3.5V
        CN6401-8 (BL_ERR): 2.3V
        CN6401-13 (REG12V): 12.7V
        CN6401-25 (TCON_VCC12V): 0V
        At the Mainboard (for example at the ICs at the top) there is 3.5V present and also at the wifi board.
        When I try to turn on the TV with the power button or with the remote control, nothing changes.
        Next I checked following:
        CN6401-7 (BL_ON) connected with 3.3V:
        The relay on the PSU clicks and switches
        CN6401-26 (TCON_ON) connected with 3.3V:
        12.7V at T-CON board but no change on panel.
        CN6401-26 (TCON_ON) connected with 3.3V and ribons between mainboard and t-con-board removed:
        12V at T-CON board and the panel changes brigthnes/color. Looks like green <-> black?!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4538
          • Italy - Milan
          check if there is a microcontroller on main board for example called PICxxxxxx, i see it probably neat the green audio jack con., it must to be rewritten, have you got an eprom programmer?
          • TobiasG
            • Sep 2022
            • 16
            • Deutschland
            No there isnt any called PICxxxxxx :/
            I attached some pictures.
            And yes i own an EPROM programmer
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4538
              • Italy - Milan
              what's the marking of IC4001? are there any other spi flash like the 2 you photographed? Is there any IC on the under side of the board?
              • lotas
                • Jan 2016
                • 4859
                • Russia
                Sony often put fuses for protection under the designation Fxxx, there are a lot of them on the board, you need to check them all with a multimeter, and the firmware is in the eMMC (IC2001).
                • TobiasG
                  • Sep 2022
                  • 16
                  • Deutschland
                  IC4001:
                  Sony CXD4760GG
                  S7NC5S2
                  1826
                  Under the board there isnt anything.
                  And no, I think there only this 2 winbond 25Q16 chips with the flash memory
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4538
                    • Italy - Milan
                    so ic4002 probably stores the stby firmware (i don't comprehend what is PiG) and must be rewritten, try desolder it, freeze it on the programmer and soon read it, then save dump and rewrite it on the same eprom, if it doesn't work another possibilty is there..
                    • TobiasG
                      • Sep 2022
                      • 16
                      • Deutschland
                      I tested the fuses and none seems to be faulty.
                      In the picture I highlighted every tested fuse
                      • TobiasG
                        • Sep 2022
                        • 16
                        • Deutschland
                        Stupid question:
                        What is the dumping and re-rewriting with the same dump supposed to do? If the chip is defective or no longer holds the correct data, then nothing changes with a new flashing of it, right?
                        And PiQ maybe stands for:
                        Prefetch Input Queue
                        • TobiasG
                          • Sep 2022
                          • 16
                          • Deutschland
                          Yes IC2001 is the eMMC (Samsung KLMAG1JETD-B041).
                          But could it be, that the firmware is faulty?
                          And if so, how could I test or fix this?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4538
                            • Italy - Milan
                            It is not the same reading normally the eprom and reading after freezing
                            • lotas
                              • Jan 2016
                              • 4859
                              • Russia
                              Yes, there may be a problem in it, the bootloader is located in it, only the EMMC programmer and a known working dump for this chassis will help here.
                              • TobiasG
                                • Sep 2022
                                • 16
                                • Deutschland
                                Briefly summarized:
                                So we all assume that the motherboard is defective and nothing else, right?
                                I have already ordered a used, tested mainboard (which I could send back, if i could find the problem with mine).
                                If it's the eMMC, then I can't get any further without a dump and programmer anyway, and unfortunately I couldn't find anything here in the forum or on google.
                                And I could still do that with the eeproms, but I'm wondering if it's worth the effort, since I almost don't assume that it's their fault?!
                                Theoretically, if the other board is delivered, I could also dump the eeproms from this board (using a clip) and then flash them again at my old board.
                                • lotas
                                  • Jan 2016
                                  • 4859
                                  • Russia
                                  Most likely they (SPI Flash) refer to T-Con, (settings for different matrices).
                                  • TobiasG
                                    • Sep 2022
                                    • 16
                                    • Deutschland
                                    I also assume that the fault is not there, since the TV shows no reaction at all. Or did I misunderstand you?
                                    For me as a layman it really sounds more like the bootloader. And is that also correct, if something doesn't fit there, the CN6401-8 (BL_ERR) just doesn't deliver 0V but like at my point 2.3V
                                    • lotas
                                      • Jan 2016
                                      • 4859
                                      • Russia
                                      Try to make a hard reset by pressing the buttons and connecting to the power supply.
                                      • TobiasG
                                        • Sep 2022
                                        • 16
                                        • Deutschland
                                        Unfortunately, I've tried that before, but without success
                                        • mmartell
                                          Sony KDL-65W850C is this a Mainboard issue ??
                                          by mmartell
                                          This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
                                          Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
                                          It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
                                          11-19-2023, 10:27 AM
                                        • TerraPhantm
                                          Sony A8H to A80J mainboard upgrade possible?
                                          by TerraPhantm
                                          I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                                          So I decided I'd experiment a little bit.
                                          I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                                          When...
                                          08-15-2023, 08:10 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
