LG B9 OLED is This a Bad Panel ?
  • mmartell
    • Oct 2013
    • 3189
    There is some banding/fine lines near the top of the screen and there is screen flickering associated with. Seems to be related to luminance; not real visible or noticable when picture information is darker.
    The defect seems to originate from that upper left corner as does the flickering.
    I have a short video I will attach to the next post as soon as I find out how to do it.
  • mmartell
    • Oct 2013
    • 3189
    Re: LG B9 OLED is This a Bad Panel ?
    Here's a short video of the defect it's not the best but it's all I've got. Maybe someone has seen it before on these sets.
    https://www.dropbox.com/s/i5vu3iqxo2...111~2.mp4?dl=0
    • Diah
      • Feb 2013
      • 6558
      i would say its dry contact at sockets lvds in general at t-con driver boards
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        That seems to me like a COF on the side has a problem.
        • mmartell
          • Oct 2013
          • 3189
          I guess based on the video I posted such as it is this is likely inconclusive at best ?
          • Diah
            • Feb 2013
            • 6558
            what kind of COF LOL... he wrote OLED
            • Oled_gambler
              LG OLED; Component-level repair on OLED panel?
              by Oled_gambler
              So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
              one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
              Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
              Looks like the actual panel is at fault. I can...
              11-22-2024, 03:58 PM
            • AK_777
              Sony KD-65A1 Repair – 4 Red Blinks Error
              by AK_777
              Hi everyone!
              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
              02-20-2025, 04:15 PM
            • Ancient1
              Interesting unusual Panel Defect ?
              by Ancient1
              Hi
              Pilot PD43S9HE Led TV . Panel model: See in photos
              Photos tell it all really. ( added Logo image photo )
              The bulge in the area before the panel Matrix .
              To me it looks like a local short that heated inside.
              Should I waste my time in flipping the panel , as if this issue can be repaired ?
              The distribution board at this end looks ok , though I did not measure anything
              What are your thoughts ?
              Cheers
              12-10-2023, 11:30 AM
              Gigabyte AERO 16 OLED BSF-73DE994SO Notebook Specification for Upgrade or Repair
              This specification for the Gigabyte AERO 16 OLED BSF-73DE994SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73DE994SO boardview and 16 OLED BSF-73DE994SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-07-2024, 06:38 AM
            • howardc64
              LG 49UJ6500 LCD panel lighter band that goes away
              by howardc64
              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
              02-19-2023, 12:13 AM
