Interesting unusual Panel Defect ?
  • Ancient1
    • 275
    • Israel
    Hi
    Pilot PD43S9HE Led TV . Panel model: See in photos
    Photos tell it all really. ( added Logo image photo )
    The bulge in the area before the panel Matrix .
    To me it looks like a local short that heated inside.
    Should I waste my time in flipping the panel , as if this issue can be repaired ?
    The distribution board at this end looks ok , though I did not measure anything
    What are your thoughts ?
    Cheers
    • 21394
    Originally posted by Ancient1
    Hi
    Cheers
    Post the TV model number,and panel model/part number https://www.badcaps.net/forum/troubl...n-thread-title
    • Ancient1
      Ancient1 commented
      Editing a comment
      Thanks , fixed . Won't happen again.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4417
    • Italy - Milan
    Hi, probably it was near a source of heat, there is a delamination where the liquid flown around damaging the transistors, to try to save it you can only drill it with a small battery drill (see Aliex, cost 15euro) and diamond 1mm tip..
    • Ancient1
      • 275
      • Israel
      Hi Davi.P
      Pressure on the Flexes does not have ANY impact on the display.
      " there is a delamination where the liquid flown around damaging the transistors" : I don't understand what "liquid" you mean ? What do you mean by "drill" ? open the bulge ?
      The distribution board is taped to the chassey, not easy to remove. Do you think there is any point flipping the Panel and checking what is underside the bulge ?
      btw - Go to local Dentist and ask if he has used drills . It is easy to adapt to a Dremel.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4417
        • Italy - Milan
        There is a liquid on every lcd panel (liquid crystal display), i mean making a hole on the bulge, first try with a needle, but it can't go trough real glass, then only chance the drill, it's not like new but maybe better..
        • Ancient1
          • 275
          • Israel
          Thanks for the advice Davi.P .
          I have diamond disc , Dentist drills , and Glass tools . Not the first time I do VERY delicate job with tiny parts ( solder wires to 0402 cap because the pads are gone ). We'll see
          • Ancient1
            • 275
            • Israel
            Hi Davi.p
            Amazing !!! And a little disapointing
            I drilled through without any issue with my dentist drill heads
            On 1st power up the screen was GOOD - Amazing
            Than after few minutes the dot lines appeared
            I tilted the TV - perhaps fluid should leak down and the situation will improve ?
            There is also a horizontal line on the upper side .. no idea if it was there before..
            Overall , I consider this another miracle repair by you
            Thank you !!! 🎅 Merry Christmass
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4417
              • Italy - Milan
              Nooooo! Stupid me...! Obviously if you drill in the inner part between the pixels the liquid leakage could only worsen...!! The right try was to drill the COG area, thus the border where there is galss integrated chip, nut not sure if that would improve also.. sorry...
              .. or.. drill a bit more and block liquid with cianoacrilyc glue (superglue)...
              • Ancient1
                • 275
                • Israel
                Where else could I drill.
                There was/is no fluid.
                The pixels area was not drilled .
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4417
                  • Italy - Milan
                  if the bulge and then the hole is not in the pixel area it's better, in fact there was no LC typical black blotch.. so i don't know.. then it wasn't a source of heat but the bulge generated by the short circuit in the COG... have you tried with signal masking? surely must be block all clocks, maybe also the VCC, VGH, VGL.. so the short overloads nothing..
                  • Ancient1
                    • 275
                    • Israel
                    The TV was brought to me from someone I guided. I told him to mask tracks and things got better - to the green hue state in the photo in my first message.
                    I did mention a short as a probable cause .
                    Anyway , The hole is a fact now. I'll leave the TV , in an angel, till tomorrow and decide . Probably throw away but sell the electronics
                    • Ancient1
                      • 275
                      • Israel
                      Watchable
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4417
                        • Italy - Milan
                        Those streaks was there before my advice?
                        • Ancient1
                          • 275
                          • Israel
                          No. Just the green hue . see first post
                          I'll try and sell
                          • Ancient1
                            • 275
                            • Israel
                            Sold
                            For ~25 EU
                            Buyer : Worked few hours and image started shaking ...
                            I explained everything to him, and he can return it .
                            but maybe ..
                            how can I easily link to a video ?
                            • nomoresonys
                              • 12212
                              • U.S.
                              Too funny
                              • AK_777
                                Sony KD-65A1 Repair – 4 Red Blinks Error
                                by AK_777
                                Hi everyone!
                                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                02-20-2025, 04:15 PM
                              • howardc64
                                LG 49UJ6500 LCD panel lighter band that goes away
                                by howardc64
                                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                02-19-2023, 12:13 AM
                              • triplefour
                                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                by triplefour
                                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                tcon is built into mainboard.
                                Only one cable goes to panel boards.
                                there is a cable from one panel board to the other that links them.
                                cost cutting measure that results in us having harder time to diagnose.
                                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                07-28-2022, 07:59 PM
                              • Storyteller12
                                QN55Q60R Service Menu Panel Help
                                by Storyteller12
                                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                01-13-2024, 01:57 PM
                              • maneatingmonkey
                                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                by maneatingmonkey
                                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                03-27-2024, 07:17 AM
