50" LG Y-sustain IPM modules
  • Wizard
    • Mar 2008
    • 2296
    Re: 50" LG Y-sustain IPM modules
    Now that more clear.
    This IPM module you can pull this 18V module and juice the 18V pins on the board using adjustable DC external power supply and find the overload.
    Cheers, Wizard
    • father_fixit
      • Sep 2007
      • 8
      Originally posted by Wizard
      What's the IPM?
      The IPM (Intelligent Power Module) is the large hybrid chip under each of the two large heatsinks on the YSUS and ZSUS boards.
      Role of IPMs
      1. Generate Sustain Waveform (square wave) – SUS IPM
      2. Energy Recovery Function (for saving power) – ER IPM
      **found info in this manual http://www.scribd.com/doc/16077007/L...07-VG-Training
      I am wrestling with a Toshiba 50HP66 with a 50X3 panel. The 18v on the YSUS measures 16.3 like others posted. On the ZSUS it measures a solid 18.0. I hope someone figures this out. I would rather repair at component level than $200 for a replacement board, but based on experiences of others, I am afraid to install new IPMs only to watch them blow in a few minutes.
      • Wizard
        • Mar 2008
        • 2296
        Thank you!!
        Cheers, Wizard
        • PowerAmpFreak
          • 982
          • Sweden
          I'm quite interested in those IPM's. I'm working as a power electronics designer, mostly smps and other applications. Anyone have a schematic of a discrete built Y-SUS board? Or better an IPM?
          What I've seen so far, this is quite straight forward stuff.
          • father_fixit
            • Sep 2007
            • 8
            The manual in the link I posted above shows a power distribution schematic of the boards. I have the .pdf file downloaded and saved.
            • Cornboats
              Dave
              • Oct 2010
              • 232
              #26
              I was interested to read that you repaired the Ipm. I've got a blown ipm from plasma 42".
              It hard to identify blown component because there nothing left-big bang, but 4 legs are remaining. There are also identical legs connected to a 10mm square component adjacent.
              is this similar to the mosfet you fitted I wonder.
              • father_fixit
                • Sep 2007
                • 8
                #27
                My 50HP66 is working great! Found a bad FET on lower Y buffer board p/n FQB46N15. Couldn't find an exact replacement from a parts house so I stole one from another project plasma ( LG 42"). That restored my VSC voltage. Then I bought a pair of C series IPMs from an ebay vendor from Texas, installed them in my YSUS, and Wa-Hoo - 50" Plasma JOY! I read many recommendations about replacing the IPMs in matched pairs and so far I am a believer as many people have replaced just one, only to have it fry within minutes. Mine has been running great for days. Not sure if it's acceptable to name the vendor. By the way, it seems that the 16.3v on the 18v circuit is OK by my experience and confirmed by the experienced vendor.
                • mbates14
                  • May 2005
                  • 169
                  #28
                  Yea, probably coppell TV repair.
                  Anyway, Can you send me that PDF? some of the pages in the scribd one isnt too clear.
                  thanks.
                  Im still fighting with this other PDP50X3 I have. I replaced the IPMs again with C series, fired it up and nothing. no pix. checked voltages, they are all present. no blown fuses. but i have not checked the 18V supply while chips are in place and secured connected to set yet either... need to check that. I had my first sustain board socketed. so i could pullt he chips right out and push them right back in. But I removed them for the simple fact of added capacitance may cause problems.
                  maybe blew the control board out too.. who knows.
                  • father_fixit
                    • Sep 2007
                    • 8
                    #29
                    By the way to remove the IPM modules from the board with minimal damage, I used an old Hand Copper made for soldering copper and lead sheet metal flashings for roofs, chimneys and plumbing pipes. I cut a slot along one corner of it with a hack saw. I let it sit and heat up with my propane torch blowing at it. I pointed the slot upward to create a trough and filled it with solder. I set the board over the hand copper with pins down and lowered it down so one row of pins dipped into the molten solder. A little wiggling and pulling and that side pulls out.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Interesting. I gather a 'hand copper' is the old fashioned soldering iron we heated with a blowtorch.
                      PlainBill
                      • bklein
                        • Nov 2010
                        • 7
                        #31
                        I have read some conflicting information regarding the 18V supply on the Zsus board - whether or not on this board it should actually be 18V. I have both IPMs out of the board. The 18V on the board still reads 16.xV. Did they decide to run at a lower voltage or is the DCDC converter or caps bad on my board?
                        Also, if one IPM was blown on my Zsus, is it a good chance a Ydrive/buffer board is bad as well? One IPM on the Ysus ran cold other hot before I discovered the bad IPM on the Zsus board. I pulled the cold one and it was fine. Ysus 18V=18V.
                        • bklein
                          • Nov 2010
                          • 7
                          #32
                          Arrgghhh.
                          Got terms Zsus and Ysus mixed up.
                          Zsus seems ok, cool IPM looked fine. 18V=18V.
                          Bad IPM on Ysus = YPPD-J015B. 18V=16.3V with both IPMs off the board.
                          • father_fixit
                            • Sep 2007
                            • 8
                            #33
                            I had 16.3v on the YSUS before and after replacing the bad IPMs. I was told by a good source that that was OK. I had 18v on my good ZSUS. That is about all the info I can give you on voltages.
                            Please check your buffer boards for bad FETs. You could blow new IPMs if you don't find them first. I had one blown on the lower Y buffer. If you don't know how to check them just dig around on google. That's what I did. Even without removing them from the board, one behaved different than the others when probed. Coppell sells them now also. When I had the bad one it killed my VSC voltage.
                            As far as IPM replacement, I strongly suggest from my research that you replace them both as a matched pair at the same time. Coppell is a good source for them. I will also add that neither of the two IPMs on my YSUS had any visual damage. The only thing that helped me key on the YSUS upper IPM as my source of trouble is that it had a snapping sound in rhythm with strobe-like flashes from the screen.
                            • Omnifix
                              • Jun 2011
                              #34
                              I know this thread is dead but I am going to do my best to get something alive on it, I have a z50px2d 50" Zenith I just picked up and I need to find the YPPD-JO15B IPM to replace the bad ones. I get the runaround from the chinese trader sites and ebay seems to have forgotten about them, as far as the removal/replacement method I have had good luck with a dremel tool and metal cutting blad to cut the pins off right next to the chip and then clean/flux and resolder the new chip directly to the old pins, it makes for easier removal and replacement since the pins are far enough up on the board to reach with solder braid on the surface, as for the heat sinks if there arent any hold to access the head of the screw I drill out the threads on the heatsink and use long through bolts with lock washers and nuts on top so you can hold the head easily with an end wrench and tighten from the top with a deep socket.
                              • fatahab
                                • Dec 2011
                                #35
                                @Omnifix
                                I got quotes for ysus IPMs from "utsource", but have not tried to buy them yet. I was going to try rebuild them like mbates and the Russians in this thread
                                In case your trying to match that specific revision I think i read on CoppelTv's blog that the series are interchangable as long as you pair it with an ER IPM in the same series, so you could get J015C or E with a matching J016C or E.
                                I picked up three of these LG 50x3 panels the last few months, a Vizio p50hdm, LG 50px5d, and a toshiba 50hp66. I was able to get one set running just by swapping ysus boards. Now I'd like to get another full set working at least for spare parts, as I'm counting on those IPM's to fail. Since I had two failed ysus boards i picked the worse one to try rebuild so if I gave up i could still send the better board to CoppellTV for rebuilding. After trying double soldering irons and a cheap soldering gun, I was able to desolder the IPM's with a heavy 1/2" 100watt soldering iron meant for plumbing or something.
                                • SpecialK
                                  • Aug 2011
                                  • 11
                                  #36
                                  I just received a J015B IPM I bought from Utsource; they offered the module at a low price and their handling time was short. So I'm pleased with their service.
                                  But... I installed the new IPM on my Z_SUS board today, and although the set works again, the IPM runs very very hot. I had the set running for a few minutes, and after that the IPM was already too hot to touch. The other modules (J016B and the modules on the Y_SUS) remain cold or become slighly warm. I'm pretty sure if I leave the set on, the J015B will pop again in less than 15 minutes. I didn't replace the J016B.
                                  18V on the Z_SUS measures 18,2V; Z_BIAS measures 94,5V, I'll adjust that later. Could that slightly higher Z_BIAS voltage be the reason why this IPM runs so hot? Or should I look elsewhere?
                                  The set is an LG 50PX4R-ZB.
                                  • father_fixit
                                    • Sep 2007
                                    • 8
                                    #37
                                    By the way I think the thing that killed my YSUS in the first place was the top two caps in the bank of orange caps next to the top heat sink. It looks like they got too hot and bled out some waxy material that dripped down the board. The first thing I did to this set was swap those two caps from a cannibalized set, but didn't help, so I disregarded the issue and went on to other components. It wasn't till I tried to fire up the set I put the leakers into, and watched an IPM blow that I realized they may have started the cascade of failing components. My theory is that the heatsinks got very hot because of inadequate cooling, caused leakage in the caps directly adjacent to it, then caps destroyed the IPM and on to the FETs. After the repair I installed cooling fans in the back cover right above the SUS boards to blow heat out. A year and a half later, still running great (and cool).
                                    • stupidcomputerrepair
                                      • Jan 2014
                                      Hi , Laptop Stevie here, I have a z50px2d. Got free. Went on , has sound , no pic. Felt all IPMS and found Ysus lower IPM(ER IPM) was cold. Removed it by loosing heat-sink with pliers till heatsink very loose then i could slip under some dikes and snip off all legs and take it out, I found blown damage on underside. Got replacement Used but "Well tested" off ebay j015b. Didnt have hot enough iron so i snipped the old legs still in Yboard to the same height and installed my replacement piggyback. This only ended up that the replacement was 1/4 inch higher off the yboard than stock, I was happy with that and reassembled the set.
                                      Fire it up and same thing. no picture. bummer
                                      removed the Drivers upper and lower and found no damage to the chips , only did close visual inspection.
                                      When i got the set i checked all voltages on the YSUS that were labled to see if all were ok, only low voltage 5v and 18 , i recall all were ok. Didn't know there is a sticker telling v's voltages so today when i get home ill recheck ll voltages including the v's. All caps in the set appear fine.
                                      Im an old Auto Mechanic, who turned laptop repairman, Im not an Electronic Tech, im trying to teach myself Tv repair. Out of about 15 Lcd's Ive gotten 10 working, Ive done mostly Caps and Boards. I do not know if i can check SM Diodes in the circuit, my only current knowledge is to check continuity in both directions, dont know how to test MOSFETS either, just printed out some sheets to follow at home.
                                      What do you guys think tho? Any hints?
                                      thanks
                                      Laptop Stevie!
                                        • Jan 2014
                                        I miswrote , I realized I had replaced the SUS IPM, not the er, I realized as I was checking all my Voltages and it was marked on the YSUS PCB.
                                        My voltages are as follows:
                                        Outputs from the PSU I measured on the PSU connector that goes to my YSUS, Va=63.2vdc, Vs=195. Then on Connector P5 ON MY YSUS board I probed and got 6.7vdc showing where its labled 5v.
                                        Grounds i probed accidentally but most show voltage when set is running, that must be usual and i just dont know it.
                                        BTW: no overheating IPMs, in fact it seems teh YSUS ones barley get warm
                                        Anyone have some input?
                                          • Jan 2014
                                          Originally posted by mbates14
                                          I forgot to note, there is an 8-pin PWM control IC that drives that 18v regulator. they are all within the same spot of the 18V regulator.
                                          What i do is have both IPMs removed, have the bare board sitting on the bench, and I hook a lab power supply up to the 5V rail, set it to 5V, and test my 18V output.
                                          this is the safest way to test the output of the regulator, without having all these rampid high voltages around while testing in the set, risking probe slippage and blowing shit up like i normally do.
                                          I have the pictures, I just have to get them off of the camera. besides, I rebuilt the ER IPM and she held up just beautiful. its the SUS IPM that blew, but i stuck a regular unrebuilt known good ER IPM in its place to eliminate that as a factor, before it blew out, and it blew out anyway.
                                          you never posted the pictures of what you replaced in order to rebuild the ipm, and a part list for what you used. id love to be able to see those pics and the list. thanks
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                          • feherhollo
                                            WSON8 NEW Bios Chips READ, ERROR, ETC.
                                            by feherhollo
                                            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                            11-26-2023, 09:33 AM
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • LukeDavis
                                            Is there a list of known dodgy ATI Radeon chips?
                                            by LukeDavis
                                            Hello again! (People are likely going to get tired of seeing posts from me lol)
                                            I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                            While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                            1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                            2. ATI Mobility Radeon X1600 and the...
                                            02-16-2024, 04:34 PM
                                          • gabrielA7
                                            Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                                            by gabrielA7
                                            Hi guys!!
                                            I have this video card on my bench, it turns on and the screen goes black!
                                            I used MATS but it showed an error in all memory modules, when writing!
                                            I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                                            Remember that I have all the debts ok, 1.35 Vram and such!
                                            Could the problem really be in the GPU?
                                            Could it be the BIOS?
                                            Thank you in advance!​
                                            06-05-2025, 09:04 AM
