kydos k32nh22cd date time problem
+ More Options
Posts
  • george_gpu
    • Dec 2015
    • 77
    • greece
    hi,
    i dont know if it is same as lg ,the time in this tv goes 1980
    do you know if has battery in mainboard ?
    can anyone send me firmware ?
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • sikocan
    Lenovo X1 Carbon 9th Gen Black Screen
    by sikocan
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    06-24-2025, 09:01 PM
  • pkslowk
    Debug Card Error Code and Solution
    by pkslowk
    Sr. Motherboard Debug Error Code Solution
    1 Intel 845 E9 Bios Related Problem
    2 Intel 845 D4 CPU Socket Related problem
    3 Intel 845 37 Bios Related Problem
    4 Intel 845 7C Bios Related Problem
    5 Intel 945GCPE 34 Bios Related Problem
    6 Gigabyte 845 2 Ram Related Problem
    7 IBM Server A6 A7 Ram Mismatch Problem
    8 Asus 845 29 CPU Related Problem
    9 Lenovo I946 97 C-Mos Jumper related
    10 Gigabyte 845 A0 CPU Related Problem
    11 Asrock G31M-VS D7 Bios Related Problem
    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
    01-28-2021, 12:51 PM
  • learnmore
    BIOS & FIRMWARE FOR Samsung QE55Q60TAUXXU DFVC2038 BN41-02756B-000 DATE: 2019.12.17
    by learnmore
    Hello Badcaps Community,
    If anyone has it or can point me in the right direction, I'm after the following:
    The mainboard and Tcon are combined into one board which has three memory ICs: 1 eMMC and 2 Winbonds
    eMMC: THGBMJG6C1LBAIL
    Bios (Flash memory): Winbond 25Q80DVSIG AND Winbond 25Q40CL (next to GPU)
    Thanks in advance,
    LL​
    03-04-2024, 08:51 AM
  • dj-bobr
    Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
    by dj-bobr
    I kindly ask for help with Thinkpad BIOS/ME repair.
    Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
    It worked fine until I tried to remove whitelist.
    Steps taken:
    - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
    - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
    03-05-2024, 04:28 AM
