Philips TV 40PFL3148H/12 keeps restarting on the logo
  • alfonzzo
    • Aug 2022
    • 55
    • fr
    My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
    After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
    Then they told me that it was a hardware problem.
    Here is a video of the problem : https://streamable.com/8ixf1u
    Thanks for your help
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Philips TV 40PFL3148H/12 keeps restarting on the logo
    So update failed or did update and not fixed the problem?
    • alfonzzo
      • Aug 2022
      • 55
      • fr
      The tv restarts over and over again as if there where no usb drive plugged. I think the usb drive is not even read by the tv, nothing happens.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Did you try unplugging then holding power button while plugging tv back in?
        • alfonzzo
          • Aug 2022
          • 55
          • fr
          Yes I tried this too. The tv bypasses everything and starts as soon as it is plugged
          • diif
            • Feb 2014
            • 6978
            • England
            Rebooting after the logo suggests faulty NAND.
            • alfonzzo
              • Aug 2022
              • 55
              • fr
              thanks, I read some threads about this too so maybe it's the case yes.
              Do you know what this nand looks like on my motherboard please, or maybe its reference? so I can try to find one online. Thank you
              • diif
                • Feb 2014
                • 6978
                • England
                Just above the scart socket.
                • alfonzzo
                  • Aug 2022
                  • 55
                  • fr
                  This one?
                  If it's the one, I think I won't be able to solder a new one it require too much precision. I can solder mosfets or like, but this kind of chips require an equipment I don't have (microscope...). Isn't there a way to program it without removing it?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I would think it's failed physically with to many bad blocks.
                    You have tried the only way to repair it without replacing it.
                    • alfonzzo
                      • Aug 2022
                      • 55
                      • fr
                      I am going to try then, since the tv will go to trash anyways nothing to lose...
                      On ebay I find lots of K9GAG08U0E SCB0, while mine is a K9GAG08U0E SIB0. Is it fine ?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        There's not much point buying an empty chip, it needs fresh contents programming in first.
                        • lotas
                          • Jan 2016
                          • 4599
                          • Russia
                          You have K9F1G08U0D, look carefully.
                          • alfonzzo
                            • Aug 2022
                            • 55
                            • fr
                            I can't do that but there are chips that come already programmed. I just have to find the correct one for my tv I guess.
                            For example this one, do you know how I can confirm if it is fine for my tv please?
                            https://www.ebay.fr/itm/173844621779...item2879f269d3
                            • alfonzzo
                              • Aug 2022
                              • 55
                              • fr
                              yes sorry my previous link was for a different chip, thanks for the reminder.
                              Is this one correct ?
                              https://www.ebay.fr/itm/115480460567
                              • lotas
                                • Jan 2016
                                • 4599
                                • Russia
                                Try different USB flash drives, but old 1-2 Gb ones are better, not all flash drives will be updated.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  No, that's for a Samsung TV.
                                  • alfonzzo
                                    • Aug 2022
                                    • 55
                                    • fr
                                    seller says "all codes BN94-0xxxx"
                                    How can I find this code?
                                    • alfonzzo
                                      • Aug 2022
                                      • 55
                                      • fr
                                      ah ok since the chip is a samsung one on my philips tv it's confusing...
                                      • alfonzzo
                                        • Aug 2022
                                        • 55
                                        • fr
                                        Well I will buy a 1gb one and retry, but honnestly I already tried with 3 usb sticks ( 8/32/128gb) and nothing happened.
