Philips TV 40PFL3148H/12 keeps restarting on the logo
  • alfonzzo
    • Aug 2022
    • 55
    • fr
    My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
    After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
    Then they told me that it was a hardware problem.
    Here is a video of the problem : https://streamable.com/8ixf1u
    Thanks for your help
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Philips TV 40PFL3148H/12 keeps restarting on the logo
    So update failed or did update and not fixed the problem?
    • alfonzzo
      • Aug 2022
      • 55
      • fr
      The tv restarts over and over again as if there where no usb drive plugged. I think the usb drive is not even read by the tv, nothing happens.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Did you try unplugging then holding power button while plugging tv back in?
        • alfonzzo
          • Aug 2022
          • 55
          • fr
          Yes I tried this too. The tv bypasses everything and starts as soon as it is plugged
          • diif
            • Feb 2014
            • 6978
            • England
            Rebooting after the logo suggests faulty NAND.
            • alfonzzo
              • Aug 2022
              • 55
              • fr
              thanks, I read some threads about this too so maybe it's the case yes.
              Do you know what this nand looks like on my motherboard please, or maybe its reference? so I can try to find one online. Thank you
              • diif
                • Feb 2014
                • 6978
                • England
                Just above the scart socket.
                • alfonzzo
                  • Aug 2022
                  • 55
                  • fr
                  This one?
                  If it's the one, I think I won't be able to solder a new one it require too much precision. I can solder mosfets or like, but this kind of chips require an equipment I don't have (microscope...). Isn't there a way to program it without removing it?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I would think it's failed physically with to many bad blocks.
                    You have tried the only way to repair it without replacing it.
                    • alfonzzo
                      • Aug 2022
                      • 55
                      • fr
                      I am going to try then, since the tv will go to trash anyways nothing to lose...
                      On ebay I find lots of K9GAG08U0E SCB0, while mine is a K9GAG08U0E SIB0. Is it fine ?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        There's not much point buying an empty chip, it needs fresh contents programming in first.
                        • lotas
                          • Jan 2016
                          • 4888
                          • Russia
                          You have K9F1G08U0D, look carefully.
                          • alfonzzo
                            • Aug 2022
                            • 55
                            • fr
                            I can't do that but there are chips that come already programmed. I just have to find the correct one for my tv I guess.
                            For example this one, do you know how I can confirm if it is fine for my tv please?
                            https://www.ebay.fr/itm/173844621779...item2879f269d3
                            • alfonzzo
                              • Aug 2022
                              • 55
                              • fr
                              yes sorry my previous link was for a different chip, thanks for the reminder.
                              Is this one correct ?
                              https://www.ebay.fr/itm/115480460567
                              • lotas
                                • Jan 2016
                                • 4888
                                • Russia
                                Try different USB flash drives, but old 1-2 Gb ones are better, not all flash drives will be updated.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  No, that's for a Samsung TV.
                                  • alfonzzo
                                    • Aug 2022
                                    • 55
                                    • fr
                                    seller says "all codes BN94-0xxxx"
                                    How can I find this code?
                                    • alfonzzo
                                      • Aug 2022
                                      • 55
                                      • fr
                                      ah ok since the chip is a samsung one on my philips tv it's confusing...
                                      • alfonzzo
                                        • Aug 2022
                                        • 55
                                        • fr
                                        Well I will buy a 1gb one and retry, but honnestly I already tried with 3 usb sticks ( 8/32/128gb) and nothing happened.
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • Magnusa2
                                          dell 5490 (la-f401p) after logo restarting
                                          by Magnusa2
                                          hii
                                          i have 5490. display coming properly . but in windows going time restarting automatically. not going in windows . i have 3 pieces same issue . any solutions have?
                                          06-19-2024, 06:26 AM
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
