Re: Philips TV keeps restarting, is this MB the same as mine please?
Hello all,
I have the exact problem. any solutions?
It didnt work with a heat gun neither.
I think I'm going to find another MB. But does someone know if a MB that has the same reference but not mounted on the same size TV, will work? thanksLeave a comment:
Ok I heat 15 minutes with a hair dryer and it didnt do much.
I will fire the heat gun this week-end.Leave a comment:
oh okay I think I understand now, you want me to use a heat gun so it can melt any bad connexion/welding and make a good contactin case of a bad one, so it fixes the tv?
I thought you asked me to remove the heat sink that's why I told you about the 2 pins to remove, in fact you asked me to heat the area so it can fix bad soldering.
Ok I will do this probably tomorrow if I can get a heat gun, I'll update you, thank you very much mateLeave a comment:
Man i am talking on solve problem if the main CPU have BGA issue (BGA mean one of it joint pints had bad contact open ) so packing the whole things could helpLeave a comment:
I have a soldering iron can I use it to melt the 2 pins instead? the heat sink really seems held by theseLeave a comment:
dont buy from aliex....
if you dont have hot air gun... use yours often but don't use it with air .. just heat the often to maximum the up and down heat... cover your mb sockets and plastic with aluminum paper don't let aluminum paper touch them just make some thing like cup to cover them.
when often reach the max put boards and don't move it at all.. after 5.7 minutes turn off the often and just open the door to keep it cool down..Leave a comment:
I only have a hair dryer it won't be enough I think. I can get a heat gun but in 4-5 days.
Meanwhile I'm trying to find another MB.
This one on aliexpress is the exact same (white sticker not exact match though, but the ref printed on the board is the same as mine 715G6092-MOD-000-004K but it was mounted on a 47" not 40")
https://fr.aliexpress.com/item/1005001623527730.html
And this one on ebay, not the same ref, last digit not the same
https://www.ebay.fr/itm/284919155130
Do you think I can buy one of these and inject my original firmware?Leave a comment:
leave it.. you need other MB... if you have hot air Gun good to try heating this heatsink from top with 280° 3 minute .. so it could help if there BGA on Soc will be connect againLeave a comment:
Thanks, here is a video I can't see any clip
https://streamable.com/ieuw8y
There is no other equipment linked to the tv, no wifi speaker nothing.
ThanksLeave a comment:
no. dont unsolder them.. from the top at the heat sink they are connected as clip.. look carfully
so what i mentioned bnefore was correct the area of the CPU realy warm and changed color...
your BL even if they are defect... yours tv will work because we dont have BL_Error pins on the socket CN9101. so the issue on MB
try to unplug any load on the MB like wifi speaker.. and turn on.. also you can disconnect the IR section too.. if thius didnt help i assume you have 99.9% BGA on the main ICLeave a comment:
Yep I just have a multimeter guys I can't capture the boot log with a USB to serial adapter.
Ok let's take a look at the CPU then, Diah could you please confirm I just have to unsolder these 2 pins to remove the heat sink and have access to the cpu? thanksLeave a comment:
LOL Maloobs, what we can more if his knowledge not as expected..
@alfonzzo:
SDM are soldering point will be find on the Main Boards if we shorted to chassis this mode will be active.. but as Maloobs wrote regard to the service manual your boards didn't have, so forget this point.
another point you didn't understand it what Maloobs wrote.. about capture the boot log. this procedure need USB TTL or USB to serial adapter and use any terminal at windows or Linux .. we connect RX and TX of the adapter to UART port which you have on the MB. this will show us the start protocol on the Terminal. i am not sure if you are able to this test point.!!
let see the area of the main CPU on the mainboards.. from downside like this photo you upload i can see there are change at the boards color caused by heating.. if this the case mean the Main CPU could got BGA issue because of the heat.. so remove first the heat sink which cover the main IC, and show us clear photo of the back side exactly the area under the Soc. and you can confirm with your eyes if what i mentioned color change was true or not.Leave a comment:
How can I boot into this SDM mode so I can get the processor informations?
I guess it's like booting into safe mode on windows laptops.
I still have the original remote, the tv doesnt respond to it though.
Ok let's follow Diah's adviceThanks guys !
I don't know about clever, but reading the serial output from the processor during the boot-up can give you a lot of information about what's going on, as shown here.
The SDM (Service Default Mode) when it was a hardware feature, and your TV is from that era, was a way to force the TV to keep all power rails on even when the TV enters protection mode.
This would allow you to measure each rail and to find short circuits.
This is what Diah was asking about to find on the main PCB.
If you had it running for 90 minutes and there was no blinking, then keep following Diah's instructions.Leave a comment:
Ok I removed the connector to be able to see all of the pins.
Here are the measures I got (connector removed).
I won't be able to take measurement with the connector on, because it's not accessible for me due to all the components around, there is no place to put the probes. So I had to remove the connector.
@Maalobs, tv is on for around 1h30 now and still rebooting, no red light.
you have 14 pins. they are 2 line of pinsLeave a comment:
<removed>Leave a comment:
Thank you much Maalobs, even if I understood half of what you wrote (because of my lack of knowledge) I'm sure it's very clever stuff
Ok I plugged the TV it's 3:48pm let's see for how long it will reboot, I'll check the red led regularly to see if it comes up.
Downloading the service manual right now thank you.
Thanks Diah for the following up. The CN9101 seems to only have 7 visible pins (I measured them in post #46) , how can I measure pins 9&10 please?Leave a comment:
thanks Maalobs. we do know the start boot script first section to load Logo there are no protection. after logo steps start the protection. from the chart i would like him first to termenated at the scoket CN9101 pins 9&10. as this line not only for audio but i think for Tuner too. if there any fault at MB audio or tuner section.. tv should boot complete.Leave a comment:
by alfonzzoHello,
My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
Then they told me that it was a hardware problem.
Here is a video of the problem : https://streamable.com/8ixf1u
Thanks for your help... -
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... -
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
- Loading...
