Philips TV keeps restarting, is this MB the same as mine please?
  • alfonzzo
    replied
    Re: Philips TV keeps restarting, is this MB the same as mine please?
    I'm never comfortable buying a mainboard til I have proven the backlights and powerboard, usually by starting powerboard as stand alone, by using jumper wires or can use resistors for safety, that's WITH cable from powerboard to mainboard UNPLUGGED.
    Seems a bit complicated for me but a few days ago I unplugged the cables that link the MB to the powerboard and nothing happened.
    replied
    I'm never comfortable buying a mainboard til I have proven the backlights and powerboard when possible, usually by starting powerboard as stand alone, by using jumper wires or can use resistors for safety, that's WITH cable from powerboard to mainboard UNPLUGGED. not familiar with this board, so I don't know which ones would need to be jumpered.
  • alfonzzo
    replied
    ok, Diah said you can enter your own code, I believe him, he hasn't lied to me yet.
    Diah seems very knowledgeable to me too, fingers crossed
  • alfonzzo
    replied
    yes that one, some philips it can be the number on the bottom of the sticker, suppose it could be the top number as well on some, can be a 12 digit string, don't have to match every single digit on the whole sticker but there's about 12 in the string that should probably match.
    ok... so I have to look at all the cards I dismissed on ebay now, to see if the numbers on this sticker match. Lots of work in perspective...
    replied
  • alfonzzo
    replied
    Originally posted by alfonzzo
    ok let me grab a screwdriver to unmount it.
    So the ebay one is okay if I put my firmware on it?
    Even if the white stickers dont match?
    here it is
    replied
  • alfonzzo
    replied
    Originally posted by Diah
    if this true its look good for 40 size TV.
    if you buy the ebay one you will have distroubted picture .. put you can inter yours panel code manuly so it become fine.
    other things still i cant see any point CSM on MB... can you show me the back side of the MB
  • Diah
    replied
    negative probe on the chassis, I find 46V for the two LED1+
  • alfonzzo
    replied
    I hope we can find a solution with Diah's instructions
  • alfonzzo
    replied
    I'm not saying it's a mainboard problem, just answering your question. you need to match up the numbers on the white stickers, not the silkscreen on the board, from what I see on the white stickers, it looks way off.
    Thanks. You mean this sticker?
    And you think it's a power board problem?
    There is another board called TCON, don't know what it is and where it is exactly, but could it be the problem ? (I find one for my model on ebay)
    replied
  • alfonzzo
    replied
  • Diah
    replied
    there are error at your measurements.. let do this... yours black DM to TV chassis and the red probe one time at each LED+ let see yours measurement.
  • alfonzzo
    replied
    There are 4 points labelled "LED1-" and they are all at around 39V
    (positive probe on the first LED1+, DC current)
  • alfonzzo
    replied
    ok they are on the power board not the main board. I'm gonna measure them hold on
  • alfonzzo
    replied
    I can send you other pics if you need.
    So with the multimeter I measure the voltage on LED- and LED1+ ? but where are these points on the board I can't find them. Continuing searching right now
  • Diah
    replied
    okay... i cant see on the MB CSM point.. if other can see please located for us.
    let do it proffisional trouble shotting.. yours TV 2013 and more old. it could be the restart from other reason.. because logo when it show on screen there are no protecting mode.. bur after logo finish start the protecting script.. this way we need to start from LED back light.
    you have on the BL socket at PSU 2 channel you need to put yours probe of DM in DC V mode and put the red on LED1+ and the black on LED- then turn on... you need to do the same if you have one more at any channel Led- listed your reading over here please to compare if we do have one channel or line at channel read less or more.
  • alfonzzo
    replied
    and the ebay card in case you need it too
  • alfonzzo
    replied
    You are giving me hope
    That's very kind really ! danke schon !
    Here are some pics of the board, along with the power board (not sure if it's its name). And a video of the tv's behavior when I plug it:
    https://streamable.com/8ixf1u
  • alfonzzo
    Philips TV 40PFL3148H/12 keeps restarting on the logo
    by alfonzzo
    My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
    After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
    Then they told me that it was a hardware problem.
    Here is a video of the problem : https://streamable.com/8ixf1u
    Thanks for your help...
    08-10-2022, 09:00 AM
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • double_DD
    Philips curling iron - is this a common AC cable?
    by double_DD
    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
    08-18-2025, 10:04 AM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
