Philips TV keeps restarting, is this MB the same as mine please?
  • alfonzzo
    • Aug 2022
    • 55
    • fr
    #61
    Re: Philips TV keeps restarting, is this MB the same as mine please?
    I only have a hair dryer it won't be enough I think. I can get a heat gun but in 4-5 days.
    Meanwhile I'm trying to find another MB.
    This one on aliexpress is the exact same (white sticker not exact match though, but the ref printed on the board is the same as mine 715G6092-MOD-000-004K but it was mounted on a 47" not 40")
    https://fr.aliexpress.com/item/1005001623527730.html
    And this one on ebay, not the same ref, last digit not the same
    https://www.ebay.fr/itm/284919155130
    Do you think I can buy one of these and inject my original firmware?
    • Diah
      • Feb 2013
      • 6614
      dont buy from aliex....
      if you dont have hot air gun... use yours often but don't use it with air .. just heat the often to maximum the up and down heat... cover your mb sockets and plastic with aluminum paper don't let aluminum paper touch them just make some thing like cup to cover them.
      when often reach the max put boards and don't move it at all.. after 5.7 minutes turn off the often and just open the door to keep it cool down..
      • alfonzzo
        • Aug 2022
        • 55
        • fr
        #63
        I have a soldering iron can I use it to melt the 2 pins instead? the heat sink really seems held by these
        • Diah
          • Feb 2013
          • 6614
          Man i am talking on solve problem if the main CPU have BGA issue (BGA mean one of it joint pints had bad contact open ) so packing the whole things could help
          • alfonzzo
            • Aug 2022
            • 55
            • fr
            #65
            oh okay I think I understand now, you want me to use a heat gun so it can melt any bad connexion/welding and make a good contactin case of a bad one, so it fixes the tv?
            I thought you asked me to remove the heat sink that's why I told you about the 2 pins to remove, in fact you asked me to heat the area so it can fix bad soldering.
            Ok I will do this probably tomorrow if I can get a heat gun, I'll update you, thank you very much mate
            • alfonzzo
              • Aug 2022
              • 55
              • fr
              #66
              Ok I heat 15 minutes with a hair dryer and it didnt do much.
              I will fire the heat gun this week-end.
              • alfonzzo
                • Aug 2022
                • 55
                • fr
                #67
                It didnt work with a heat gun neither.
                I think I'm going to find another MB. But does someone know if a MB that has the same reference but not mounted on the same size TV, will work? thanks
                • ljubisa86
                  • Dec 2014
                  • macedonia
                  #68
                  Hello all,
                  I have the exact problem. any solutions?
                  • alfonzzo
                    Philips TV 40PFL3148H/12 keeps restarting on the logo
                    by alfonzzo
                    My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
                    After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
                    Then they told me that it was a hardware problem.
                    Here is a video of the problem : https://streamable.com/8ixf1u
                    Thanks for your help...
                    08-10-2022, 09:00 AM
                  • Sharpa
                    Repair attempt Philips 55OLED804/12
                    by Sharpa
                    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                    The symptoms when bought: Philips logo appears then tv turns off
                    Things tried so far:
                    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                    Yesterday, 08:30 AM
                  • alro7779
                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                    by alro7779
                    Hello, guys!
                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                    09-14-2025, 12:25 AM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
