Transformer MIP260T-T102 (RCA L26HD31) Help
  • rb0746
    • Jan 2010
    • 42
    I have picked up this set recently and the set will operate for about 10 minutes with intermittent high pitch sounds then will shut down. I think I have isolated the problem it being a transformer MIP260T-T102 . If I cool this transformer when the whining begins the whining goes away. And if I don't the set shuts down !. where to get this transformer from is my problem now any help ?
    I will attach a picture it is the little transformer with the white label .
    Cheers
    Ron
    When I told my doctor I broke my leg in two places while carrying a big Monitor, he told me to stop going to those places.
  • el3ctroded
    • Nov 2008
    • 198
    Re: Transformer MIP260T-T102 (RCA L26HD31) Help
    I would like to point out that when cooling T102 you are cooling a lot of other things in that area... In particular U102 and CON1 and Q101 and D101.
    Using an infrared thermometer you can pin-point the hot-spot... And a pic of the other side of the board would help.
    • rb0746
      • Jan 2010
      • 42
      point well taken . I used a small diameter rubber tube and did several test with the same result does this help ? And I also did a re solder on the obvious points
      Cheers
      Ron
      • Scenic
        o.O
        • Sep 2007
        • 2640
        getting rid of all the C(r)apXon KM would be the first thing i'd try..
        they usually dry out.. no bloating..
        • rb0746
          • Jan 2010
          • 42
          Well I have found the problem( bad cable connection ) seems the controller was messing signals up .
          Cheers
          Ron
          • SparkeyJim
            • Oct 2011
            • 3
            Does someone in the forum know where I can obtain a schematic drawing for the MEGMEET MIP260T power supply? I have one that needs repaired. It has some blown smd's and also some electrolitics.
            Thanks in advance for any help.
            SparkeyJIm
            • SparkeyJim
              • Oct 2011
              • 3
              I have located the schematic for the MIP260T power supply now all I have to do is the diagnostic work and replace capacitors C109 and C110 right off . Both are shorted. As for T102 you may want to try Thompson Consumer Electronics. They use that same supply in their L26HD31 LCD TV.
              • amro eid
                • Apr 2014
                • 5
                • egypt
                if u have schematic please upload
                i/p board number MIP260T
                REV A2
                2008,05.17 MADE IN CHINA
                OR NEED DATASHEET FOR IC SG3525AN
                CPBS0848G
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
                  ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 04:40 PM
                  ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 12:00 PM
