can you damage screen panel with high voltage
  • CroBUTKO91
    • Jul 2022
    • 22
    • Croatia
    hi i have philips led tv i had vertical lines all over the screen so i was testing voltages on board connected directly to screen below t-con
    i accidently shorted two caps just above flat cables going to screen 20v and 2v and the 2/3 of the left side of the screen has gone white but vertical lines are still there i still have all the voltages on caps nothing is shorted so im just wondering is it posible i damaged the screen (burned pixels) when i shorted caps ot its posible the t-con board got damaged, thank you
  • JDC
    • May 2015
    • 273
    Re: can you damage screen panel with high voltage
    Yes, it is possible.
    • CroBUTKO91
      • Jul 2022
      • 22
      • Croatia
      Thank you i ordered new tcon board will post update
      • JDC
        • May 2015
        • 273
        Be careful, though: it is possible to damage a new tcon due to a fault with the panel.
        • CroBUTKO91
          • Jul 2022
          • 22
          • Croatia
          Thank you tcon is not so exspensive so i will take that risk
          • angelos
            • Dec 2012
            • 573
            • South Africa
            If I understood you correctly you made a short on the board that connects between the TCON and glass panel (Scaler board), If so I reckon you have killed the TCOF IC on those flex ribbons that are connected to the glass. Say goodbye!
            If you gently touch the TCOF IC and test for heat you might compare its heat to others on the panel. You might find out its getting hot which means its burnt. New panel replacement or to the rubbish bin it goes.
            • CroBUTKO91
              • Jul 2022
              • 22
              • Croatia
              New tcon didnt resolve the problem going for parts now this pannel doesent have cof chips strange but i removed plastic covering panel and no cofs
              • nomoresonys
                • 12306
                • U.S.
                go ahead and carefully, no more shorting, test those little caps on the panel driver board for shorts or very low ohms, may be some other components like a diode pack to check.
                • CroBUTKO91
                  • Jul 2022
                  • 22
                  • Croatia
                  I did test all o got all voltages no shorts or low ohms i already scraped tv
                  • nomoresonys
                    • 12306
                    • U.S.
                    for the best, too technical, beyond your "scope"
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • jkruns
                      M1 A2338 screen and touchbar issues after cleaning up liquid damage
                      by jkruns
                      This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                      My patient is an A2338 Macbook Pro M1 (late 2020).
                      It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                      04-22-2024, 06:45 AM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • odie34
                      Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                      by odie34
                      I am a hobbyist (not a professional) so please be gentle...
                      I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                      I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                      02-18-2024, 09:11 AM
