Grundig 49 VLE 420 BN - no picture
  • betmen
    • May 2019
    • 90
    • Croatia
    I bought this used TV as defective, it does not show any picture or menu screen.
    When it is turned on, there is no picture, but the backlight works.
    The motherboard is ZG7190R-9 and it is probably defective.
    Through ads I can buy a cheap TV Grundig tv 43 gua 7000 Barcelona with a broken screen. How can I find out which motherboard is in that TV because if it doesn't match I wouldn't buy it.
    Stickers from both TVs are attached.
  • thommyX
    • Apr 2016
    • 93
    Re: Grundig 49 VLE 420 BN - no picture
    49Vle is a G5 chassis with ZG7190R chassis and NX with ZG2190R chassis. These are not compatible. You have to have a mainboard from a G5 or G7 device. But it has to be 49 inches and the same panel has to be inside. Best only G5. Then pay attention to the white sticker on the CI shaft. There are letters or numbers there. The first three have to be identical, otherwise the mainboard does not match the panel and there is no picture. You can't change panel data.
    Greetings Thomas
    • lotas
      • Jan 2016
      • 4662
      • Russia
      If there is no image, the problem may not be in the motherboard, but in the T-CON, in
      panel slats or in the panel itself.
      • betmen
        • May 2019
        • 90
        • Croatia
        Greetings Thomas
        Thanks for the information.
        Can you tell me where can I find information which motherboard is in which TV set?
        • betmen
          • May 2019
          • 90
          • Croatia
          There in no separate T-CON board in this TV.
          • lotas
            • Jan 2016
            • 4662
            • Russia
            T-CON can be built into the motherboard itself, it can be a separate module, or it can be soldered onto the strips of the panel itself.
            • betmen
              • May 2019
              • 90
              • Croatia
              I think it is in motherboard thats why I think motherboard is the problem.
              • lotas
                • Jan 2016
                • 4662
                • Russia
                Without a photo, I can't tell you where your t-con is.
                • betmen
                  • May 2019
                  • 90
                  • Croatia
                  Here are the photos.
                  • lotas
                    • Jan 2016
                    • 4662
                    • Russia
                    This is the T-CON, soldered on the matrix bar, check the fuse and it should have DC + 12V relative to ground.
                    • betmen
                      • May 2019
                      • 90
                      • Croatia
                      There is 11,88 V before and after the fuse (so the fuse is ok) and there is 3,21V on the test point VCC 3,3V. (left corner on the picture).
                      Also, there are folloving voltages on the CN3 on the power board, when the tv is on and backlight is working, PINS 1-14:
                      1 5,13V
                      2. 0V
                      3. 11,92V
                      4. 11,92V
                      5. 11,92V
                      6. 0V
                      7. 0V
                      8. 0V
                      9. 24V
                      10. 3,22V
                      11. 0V
                      12. 0V
                      13. 0,62V
                      14. 3,13V
                        • 12206
                        • U.S.
                        need to label the pins, example: Pin #
                        1 FAIL COUNT 0
                        2 ANA-DIM 0
                        3 A13V 9.67
                        4 OD ON/OFF 0
                        5 A13V 9.67
                        6 BLU_PWM 0
                        7 A13V 9.67
                        8 POWER_ON/OFF .103
                        9 A13V 9.67
                        10 GND 0
                        11 GND 0
                        12 GND 0
                        • betmen
                          • May 2019
                          • 90
                          • Croatia
                          1 FAIL COUNT 0
                          2 ANA-DIM 0
                          3 A13V 9.67
                          4 OD ON/OFF 0
                          5 A13V 9.67
                          6 BLU_PWM 0
                          7 A13V 9.67
                          8 POWER_ON/OFF .103
                          9 A13V 9.67
                          10 GND 0
                          11 GND 0
                          12 GND 0
                          Pin labeal is on this picture:
                            • 12206
                            • U.S.
                            it's hard to see, what is 11 and 12?
                              • 12206
                              • U.S.
                              do further testing on tcon, test the little capacitors for shorts or very low ohms.
                              • betmen
                                • May 2019
                                • 90
                                • Croatia
                                11 - dim0
                                12 - dim1
                                13 - dim2
                                14 - bl
                                  • 12206
                                  • U.S.
                                  unhook tcon from mainboard and do those tests on the caps.
                                  • betmen
                                    • May 2019
                                    • 90
                                    • Croatia
                                    I do`t think prooblem is on the T-CON, because it have voltages, I think problem is the motherboard.
                                    I already thought to take out the t-con, but for that I have to disassemble everything, remove both plates and the tin cover to get to the t-con.
                                    I will do it when I will have some time.
                                      • 12206
                                      • U.S.
                                      from the picture there, you have all the access you need, no need to remove it to test the caps, pretty simple basic test.
                                      • betmen
                                        • May 2019
                                        • 90
                                        • Croatia
                                        I have already tested the ones that are visible, but only a small part of the entire screen panel is accessible through the opening that is visible
                                        • betmen
                                          Grundig 40VLE4421 - no picture
                                          by betmen
                                          I changed few leds on led background and tv works for about one year.
                                          It is not much in use.Then stops working again, I checked leds on background, all are ok.
                                          When I light up the screen with lamp there is a picture but background is not working and you can`t se the picture on the screen.
                                          When I touch connector for led background with probes of backlight tester they light up and tester shows 108V. After that TV turn on normaly and picture is ok, backlight is working. After TV is turn of again backligt is not working, just on first turning on GRUNGDIG picture on boot is shown...
                                          06-04-2022, 08:12 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
