Grundig 40VLE4421 - no picture
  • betmen
    • May 2019
    • 90
    • Croatia
    Re: Grundig 40VLE4421 - no picture
    Originally posted by thommyX
    There are almost 2 mistakes at Chassis Ty.
    Defective mainboard or defective lighting.
    The lighting is definitely to blame for you.
    Your LED strips are called ZCC606 and these always cause problems when repairing them. Always exchange completely.
    Any software that posts "diah" here is from my forum iwenzo.de
    Your software is old, but has nothing to do with your mistake.
    https://www.dropbox.com/s/omflqxh0a2...02.00.rar?dl=0
    LG Thomas
    Thanks,
    I was at holiday until now,
    I will try to get new LED strips...
    • betmen
      • May 2019
      • 90
      • Croatia
      I finally fixed the backlight, I tested one by one led diode with the instrument in diode mode and the 39th out of 40 in total was broken, When tested with the led tester it lights up again and then shows as if it is good. Then I connected it to a rectifier with a stronger current and then it stopped working, I guess this happened all the time before.
      I replaced that diode and now the backlight works every time.
      As this was my fifth time disassembling this TV, the screen cracked last time, but there was a picture when the backlight was working.
      Now when turning on the GRUNDIG inscription appears, then a black screen appears, then GRUNDIG again, which quickly fades and only a black screen remains. neither the menu screen nor the TV responds to the remote.
      I'm confused if it's because of the cracked screen or if it's the motherboard?
      The TV does not have a separate T-CON board.
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • betmen
        Grundig 49 VLE 420 BN - no picture
        by betmen
        I bought this used TV as defective, it does not show any picture or menu screen.
        When it is turned on, there is no picture, but the backlight works.
        The motherboard is ZG7190R-9 and it is probably defective.
        Through ads I can buy a cheap TV Grundig tv 43 gua 7000 Barcelona with a broken screen. How can I find out which motherboard is in that TV because if it doesn't match I wouldn't buy it.
        Stickers from both TVs are attached....
        07-15-2022, 10:08 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • Pipolups
        Corsair K70 LUX RGB dying LEDs
        by Pipolups
        Hi there !
        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
        10-08-2024, 11:58 AM
