SAMSUNG PLASMA TV PS51E550D 1W shorted BDXXX on board
  • LanTHrusteR
    • Jan 2021
    • Russia
    SAMSUNG TV PS51E550D 1W,
    Symptoms: the panel is on but no picture, fuzzy color vertical lines at the black background at both sides of the panel. Very similar to this:
    Disconnecting left side of the panel fixed the right side which went on and displayed picture although with vertical black bars coming from the middle X-BUFFER panel at the bottom of TV and the same 1 fuzzy color vertical line ~ 0.11 inches long and a few 1 pixel black bars. The disconnected left side showed fuzzy colorful bars, may be some glimpses of the the correct image from menu at the right side of the screen.
    Taping pins at the left side ribbon only led to the black background with the same fuzzy vertical color bars and black bars. About 20% of the left panel is covered in them. T-CON seems normal.
    Going to X-Buffer panels (left middle right) revealed strange SMD BDXXXX marked elements which looked like diodes with cathode markup lifting some of them revealed that they are all shorted out both ways. About 90% of them on the x-buffer boards are shorted.
    I'm confused, is it normal, is it a diode? Can it be that all of them are shorted even at the X-Buffer side that shows picture? How to check them? They show 0 resistance both ways when lifted - all of them like coils yet they marked as BD and have cathode marked.
    What am I missing here? Are they all just shorted on all x-buffers? What purpose on X-Buffer boards do they serve? How is it possible that all of them are shorted and yet right side of the panel seems function almost normally?
  • R_J
    • Jun 2012
    • 9623
    Re: SAMSUNG PLASMA TV PS51E550D 1W shorted BDXXX on board
    They are likely ferrite beads, basically a coil (will check shorted)
    • Bousty
      VRM shorted, low side shorted ?
      by Bousty
      my motherboard, a Gigabyte b660m-DS3H, broke last night, and I'm trying to fix it.
      The symptoms are as follows:
      - The PC doesn't boot when the CPU power supply is connected (without CPU).
      - When voltage is applied to the CPU connection, the three phase 2 MOSFETs start to heat up. The other MOSFETs do not heat up.
      The phases are made up of one high-side and two low-side MOSFETs.
      My hypothesis is that if the two Low MOSFETs are hot, they must be permanently ON, even when the High is ON, causing a short-circuit.
      Do you know how...
      09-01-2024, 06:14 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Yanleb
      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
      by Yanleb
      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
      D608, good
      D618 RF101L4S, good (See warning 1 below)
      D619 RF101L4S, good (See warning 1 below)
      D865 RF101L4S, shorted (See warning 1 below)
      IC464 Inverter HA MC74HC1G14, shorted...
      03-09-2020, 12:00 AM
    • flibidy
      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
      by flibidy
      I have here a Magnum IA.100 which belongs to my parents.
      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
      What Ive done........
      01-01-2025, 01:26 PM
    • BalkanBoy
      Dead Razer Blade 14 2022, shorted CPU?
      by BalkanBoy
      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
      I removed coil and injected 0.7V, it draw around...
      09-27-2024, 12:44 PM
