Soyo VT17N71
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Soyo VT17N71
    Originally posted by bsweasel
    Its a dual color LED. one LED that lights both green and orange. I'm guessing its green when power is on, and orange in sleep mode.
    If it is ONE LED, how can it be two colors at once?
    When you power off the LCD, and plug it in? Does it go green first?
    The sequence and timing of makes a huge difference on what to look troubleshoot next. That is why this question is so specific.
    --- begin sig file ---
    --- end sig file ---
    • bsweasel
      • Jun 2010
      • 82
      Re: Soyo VT17N71
      Both green and orange light up at the same time.
      As soon as I plug in the Power supply. the ONE dual color LED lights up both colors at once. I tried to take a picture of the LED, but it does not show up, it washes out and you can't tell both colors are lit. You can see at the base of the LED that both colors are lit at the same time in person...you'll have to trust me on this one.......
      They never change to one or the other and they stay on till I unplug it.
      Also, my laptop "detects" it with plug and play beep.
      The logic board is putting out 11.3 vdc to the inverter board, have 2 inverters since I have 2 monitors and neither seem to make a difference.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Re: Soyo VT17N71
        just orange/green instead of red/green
        • PlainBill
          • Feb 2009
          • 7034
          Re: Soyo VT17N71
          Ther is a simple explanation for this. There appears to be two 'processors' on the logic card. One handles the interaction with the front panel, backlights, and also turns on the power to the LCD panel. The other handles the video signal. The first one is defective, and is cycling the power LED at a high rate.
          PlainBill
          • bsweasel
            • Jun 2010
            • 82
            Re: Soyo VT17N71
            So, does anyone have any other ideas on what to test next? I'm going to start on the other board I think...maybe I'll have better luck.... Can anyone suggest a cross reference for the mosfet listed above? I can't find them at digikey, mouser, jameco, or on google searches???
            • Geragus
              #46
              Re: Soyo VT17N71
              hello, i have the same problem with my Soyo, exactly the same components broken... you fixed it??
              • bsweasel
                • Jun 2010
                • 82
                Re: Soyo VT17N71
                No, put it on the back burner. Now it will most likely end up in the trash. I don't even remember what the last thing was I tried.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  Re: Soyo VT17N71
                  I suggest posting your monitor on your local craiglist/kijiji to give away as others may be able to use parts.
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                  • MrzPdlch
                    Blown fuses on Gigabyte GTX 980TI 6GB
                    by MrzPdlch
                    Hey everyone,
                    I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                    Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                    Find some pictures of the actual GPU together with a picture of how it should look like.
                    I also wonder whther it might be a problem that there...
                    03-10-2024, 04:14 PM
                  • BMCappelletti
                    Sonos Play 1 with blown cap and fuses
                    by BMCappelletti
                    Hi there.
                    I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                    Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                    Where should I start looking for the main fault?
                    Thank you....
                    08-10-2023, 04:02 PM
                  • gozotto
                    Sharp LC-40LE812E fuses blown
                    by gozotto
                    I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
                    All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
                    Thanks in Advance
                    gozotto
                    04-04-2022, 12:14 PM
                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                    by sam_sam_sam
                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                    12-14-2023, 07:45 PM
