Insignia FireTV NS-50DF81NA19 backlight on but no image
  • jason123
    • Oct 2015
    • 1068
    Hoping for some help as i am perplexed by this one. Backlight comes on fine, unit is responsive to remote, and all indications are good. VM and VA rails coming from power supply are around 16 V. Green LED on the TCON comes on.
    2 ribbon cables from TCON 2 panel act normally i think. Disconecting the left one results in right hand side of the screen white. Disconnecting the right ribbon, has no effect (full dark screen)
    So.. thought it's TCON...got one but TV acts the same (just backlight and no picture.) So i got a main board, and the TV still acts the same. What the heck. Could be bad panel? Visual inspection shows nothing burnt or odd.
    Any thoughts? Tried disconnecting the wifi / bluetooth module. No effect. Help!
  • CapLeaker
    Leaking Member
    • 8150
    Re: Insignia FireTV NS-50DF81NA19 backlight on but no image
    Those two ribbons on the tcon go to another board each. My bet is the board on the side that stays black.
    • jason123
      • Oct 2015
      • 1068
      Do you mean the panel tab boards? I usually see burn mark or some indication of failure. These panel tabs look pristine. And i would think if one side is bad the other side would show an image? I cleaned the ribbon pins with alcohol and no change
        • 12184
        • U.S.
        maybe try the "tape cut-off' method.
        • CapLeaker
          Leaking Member
          • 8150
          Only because it looks good, it doesn't mean it is good. It doesn't have the right symptoms for bad tab bonds. But symptoms also do fit for those little small boards to be the problem. There should be test points called like VGL etc check them and compare them.
          Also only on the assumption to swap a new board in, also doesn't mean you got a working board. That has been proven here many times.
          Nomoresonys mentioned the tape cutoff method. That would be my last resort. Get some help if you do this, to make sure to cut off the right one.
          For starters, I'd put a TV show or something on one of the inputs and probe the LVDS with an oscilloscope. If you see small changes as the picture changes, the main board is good. Then your off to the tcon checking for voltages, panel Power etc.
          • jason123
            • Oct 2015
            • 1068
            I get you.. just typically, if there is a problem on these tabs, there is burn marks or other visible issue.
            Not much is labeled on these boards. I went around the cpas (bypass I presume) and some have 3.2 V, others don't have any voltage on them. Many measured short (which I wouldn't expect on these capacitors) and there are so many - took a chance and removed a few to see if I can get lucky, but I wasn't ... there are still many with 0 Ohm across.
            Agree - I just wouldn't have expected the exact same symptoms from 2 main boards and 2 TCON boards. But, I could very well have received bad boards.
            I have activity on every pin almost of the LVDS - very ugly captures with a scope but I don't have the right probes anyway for this measurement.
            I'm giving up I think on this one.. I think the panel is bad and I can't seem to find easily a bad part or section on the tabs.
            Thanks for the help
            • neilc6
              • Nov 2015
              • 1550
              With panel boards, shorted chip caps will be a likely suspect if a new tcon didn't fix it. There is a youtube video of a guy isolating the short with a milliohmmeter. https://www.badcaps.net/forum/showthread.php?t=105788
              Tape cutoff typically works if you can get one side to show a good screen since you are blocking signals to the bad side with the good side compensating.
                • 12184
                • U.S.
                I have used the tape cut-off successfully on more than one totally dead set, meaning no signs of life at plug in or turn on. Just got 15 clunkers in today, I expect it will prolly work on at least 5 of them.
                • CapLeaker
                  Leaking Member
                  • 8150
                  As long as you can see differences with the oscilloscope in the lvds when the pictures changes your main board is working.
                  • SteamTrap
                    NS-43DR710CA17 Insignia - Backlight but no image
                    by SteamTrap
                    Hello!
                    I am attempting to repair an Insignia TV that a friend gave me.
                    At first I thought it would be a backlight issue which is quite common apparently on these models but when powered on, the backlight is visible and the screen lights up but no image appears. Also there is a bright spot visible in the bottom left corner (see image attached). I can also hear sound when I press the remote buttons and there is no visible impacts on the screen.
                    I tried to unplug the controller board and it made no difference so i'm wondering if the issue could comes from the...
                    10-27-2021, 08:17 PM
                  • Salem Aboshala
                    820-00138-A got image but no backlight
                    by Salem Aboshala
                    Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                    I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                    History: my laptop backlight stopped working without any reason.
                    Symptoms:
                    I have image on screen using my flashlight.
                    I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                    Keyboard backlight still working and can be adjusted normally.
                    Since two days I tried to follow all similar...
                    06-11-2024, 03:02 PM
                  • Constantinos
                    Macbook Pro A2442 820-02098 No image but has backlight
                    by Constantinos
                    Hi all
                    I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                    He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                    Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                    Obviously, he decided against this and gave it to me so that I could have a crack at it.
                    From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                    08-24-2024, 09:48 AM
                  • ajgae
                    HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                    by ajgae
                    Hi everyone!
                    First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                    03-06-2025, 09:53 AM
                  • learnmore
                    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                    by learnmore
                    Hello Community!
                    CASE DETAILS
                    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                    Tried inserting firmware on USB and left it in for a few hours, but no change
                    03-03-2024, 09:49 AM
