Philips 42PF9630A/37 horizontal lines
  • mrosenberg42
    • Aug 2008
    • 27
    I have two of these plasmas. One only the top of the screen has these horizontal lines and the other plasma both the top and bottom of the screen has the horizontal lines. The lines seem to be red, green, blue and black. I have done alot of research and this seems to be a buffer board failure. My question is what specifically on these buffer boards are failing and can these be repaired to the component level? I would like to repair the boards rather than swapping. I read somewhere that these might be cold solder joint connection issues but we all know that would be just to easy. I believe I can check the buffer chips one by one for shorting but I think if they shorted to ground the plasma wouldn't even startup. If it is a chip failure can they be removed and replaced? Below are the pics of the plasma that shows the worst signs of the issue. Any help would be much appreciated. Thank You.
  • mrosenberg42
    • Aug 2008
    • 27
    Re: Philips 42PF9630A/37 horizontal lines
    Someone has got to have some knowledge of these buffer boards. There are a few companies on ebay that are giving a core of $25 to send in your old board after you buy a refurb from them. They are fixing them and reselling. Anyone?
    • el3ctroded
      • Nov 2008
      • 198
      I don't have any actual experience with that, but my thoughts are: Sure you could do chip replacement, if you have the proper tools and soldering experience with high density pin counts. That is likely what the company on ebay is doing, either that or they have contact with a manufacturer who refurbs the boards for them...
      High-density chips aren't too hard to solder by hand, once you get the hang of it...
      • retiredcaps
        • Apr 2010
        • 9271
        I'm amazed by the soldering skill required to do this. See this video (about 9 minutes) on Surface Mount Soldering
        http://www.youtube.com/user/CuriousI...31/3NN7UGWYmBY
        --- begin sig file ---
        --- end sig file ---
        • Wizard
          • Mar 2008
          • 2296
          These are not Y-buffer failure. You have either bad logic board or mainboard.
          Cheers, Wizard
          • mrosenberg42
            • Aug 2008
            • 27
            Thanks for the comments. All very helpful. That you tube video is very interesting. As I have been in the electronics industry for years I am sure the soldering won't be a problem I'm just not sure that the buffer chips are the problem. Maybe other components on the board. As Wizard said it may be a bad logic board or main board. As I am not doubting the knowledge of someone who knows infinitely more than me and always will, I still think the buffer boards are the problem. I have read numerous forums of people with the same problem that looked exactly like my picture and the fix was the buffer boards. So now for the plan. Like I said. I have two of these tv's same model number. The 1st plasma has the issue across the whole screen and the second plasma just half the screen is plagued. I am going to remove the buffer that is good and install it in the plasma that the whole screen has the issue. If half the screen comes back good then I feel confident the buffers are the source of the problem. In that scenario I am back to square one. What on the buffer boards are failing? Can a buffer chip fail in that manner or is it more likely other components on the buffer board? I am going to try the buffer swap hopefully within the next couple of days. We had our basement flood and it is now priority. Once again thanks for all the help. Long live badcaps.net!!!!
            • nuryev
              • Mar 2010
              • 8
              A friend has offered me his Philips 42inch plasma TV after describing a similar 'horizontal lines' problem with display regardless of input source.
              Any new suggestions or experiences to share?
              • mbates14
                • May 2005
                • 169
                I had a 50" Hitachi that done the same thing. replaced buffers, issue gone.
                • nuryev
                  • Mar 2010
                  • 8
                  hi
                  thanks for the response - can you recall what were the boards you replaced, were they LJ92-01203A?? and the supplier? did you repair it yourself
                  • mrosenberg42
                    • Aug 2008
                    • 27
                    So after way too long I finally ordered an upper buffer board. I put the board in and the picture looked great. So I put on a dvd with the back of the TV off and let it run for an hour burn in. No problems.
                    So I installed the back cover of the TV and let it run for about 20 min. and the lines on the upper half of the display started to reappear.
                    I quickly shut off the TV to avoid damaging the upper buffer board that I just put in. Let it rest for about 15min. and turned it back on. No more lines seen.
                    So do you think the buffer board is being driven to hard causing the lines or is it heat related?
                    The bottom half of the screen is fine all the time.
                    Should I compare the voltage being sent to the lower buffer board vs. the upper buffer board voltage or is this maybe a component on the Y sus board being heated up and causing the anomally.
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      Has anybody ever tried replacing the large blue plastic coated capacitors. On my set they are labled as MPP 335K 2F.
                      • Wizard
                        • Mar 2008
                        • 2296
                        these are not the upper buffers, you need to isolate the problem to logic board or the mainboard. Tip: put up menu. is it good or bad? Good, mainboard is bad due to defective IC because menu is input ahead of the bad IC that only processes the video or bad means logic board is a problem. The lines is missing address line that drives the buffers by bus address that addresses horizontal and vertical lines.
                        Cheers, Wizard
                        • mrosenberg42
                          • Aug 2008
                          • 27
                          With the old upper buffer board in the horizontal lines are always present. With the new upper buffer board in the lines are now gone but after about 15min of the set warming up with the cover on the lines started to slowly fade in, which is when I turned the set off.
                          The lines are there regardless of input and are also there with the menu up when the old board is installed (the original upper buffer board).
                          Wizard,
                          If the problem is the logic board like you suggest from your hint (because the horizontal lines are present when the menu is up) then why does the new upper buffer board at least temporarily cure the problem?
                          I am thoroughly confused. I have read several forums where several people have had the same problems with the same philips chasis and it seems the fix was always bad buffer boards. I am wondering now if this was a temporary fix as in my case.
                          What do you think the problem components on the logic board would be? I will now be taking a closer look at that. Anything to point me in the right direction would be appreciated. Thanks.
                          • Wizard
                            • Mar 2008
                            • 2296
                            Buffer boards decodes the address lines bus and put one line up for each bus cycle and inject how much brightness after one trigger by the X drive to get plasma cell to light up. Y and Z buffers works together on brightness. The X drive get that pixel to light. Y buffers addresses one line at a time, Z strobes other lines at same time, they are driven just enough to have little precharge all the pixels and just a little trigger by the X (columns) get that cell to alight and sustain, amount of brightness depends on how much voltage applied to that cell by both Y and Z circuits.
                            Y and X are addressed one pixel at a time with two addresses to place where given line is and a pixel is lit by the X address last. One stuck bit on either Y or X adddress repeats across the screen like you see. The bad address is on the Y bus address bus. That can be either generated bad data from mainboard or the logic board.
                            Buffer board when defective, it will show up in one IC as noisy lines in one band or blank or IC physically blown out. X buffers is integral to panel itself. If X buffer is bad, panel is junk instantly.
                            This fault repeats across whole panel, cannot be the Y-buffer boards (the long thin vertical boards on left side, not the YSUS board (that one with heatsinks attached to the Y buffer boards).
                            Ohh, I see you had menu displayed, that means fault lies with the logic board, not the Y buffer or mainboard itself. It can happen rarely with mainboard, do the logic board first.
                            Cheers, Wizard
                            • mrosenberg42
                              • Aug 2008
                              • 27
                              Wizard,
                              Thanks for all the help. One more question. Like I said early on in the post, I have 2 of these TV's exact same model number one has horizontal lines throughout the whole screen as pictured above and the other has horizontal lines only through the upper half of the picture (have not attached a pic of that set).
                              Is it possible that the logic board would cause the problem on only the upper half of the screen while the remaining lower half of the picture is perfectly good?
                              Both tv sets have the exact same symptoms with one exception; one tv set the whole picture is bad and the other set only the upper half is bad.
                              So if I am logically thinking about this then moving the logic board from one set to the other should move which tv shows the lower half of the screen as being good. Thus confirming or ruling out the logic board. Correct?
                              And if the problem does not move with the logic board swapping the mainboard between the sets would also confirm or rule out the mainboard.
                              Please let me know if I am logically thinking this through. Thanks again.
                              • Wizard
                                • Mar 2008
                                • 2296
                                post the pic on that tv with panel half with lines.
                                Cheers, Wizard
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Originally posted by mrosenberg42
                                  Wizard,
                                  General troubleshooting technique. If a board is transferred between two sets and the problem follows the board, the board is most likely at fault.
                                  PlainBill
                                  • mrosenberg42
                                    • Aug 2008
                                    • 27
                                    Here are pictures from the set where half the screen is good. I have checked the buffer board for shorts with the method described by coppell tv repair and the board has no shorts and seems OK. Although the heat sinks on the buffer chips get quite hot. Could this be connector solder joints not making good contact on the buffer board?
                                    For a test I put the new upper buffer board back in. With the back cover off I let it run for two hours. No problems. After the two hour mark the buffer chips on the new board start to heat up and the upper half of the screen has lines jumping in and out of the picture. I took a hefty fan and cooled down the upper buffer board while it is still running. The lines disappear for 10 or 15 minutes and then start to come back till I cool it back down.
                                    Like I said I don't want to damage the upper buffer but I do want to figure out what is going on. Thanks to all involved for the help.
                                    • Wizard
                                      • Mar 2008
                                      • 2296
                                      I still think best to try with different logic board as well.
                                      Cheers, Wizard
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        If you put a fan on the one that starts doing it with the cover on does it still do it?
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • grandad99
                                          philips 58PUS8105/12 horizontal lines
                                          by grandad99
                                          hi all and hoping i could get some help please.
                                          my philips 58PUS8105/12 has started acting weird.
                                          its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
                                          tv prob 3 years old and only used on weekends for a few hours so not done much.
                                          i popped the back off and cleaned the ribbon contacts all to no...
                                          08-01-2023, 10:37 AM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • rstrube
                                          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                                          by rstrube
                                          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                                          Hi Everyone,
                                          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                                          11-23-2025, 01:37 PM
