Sony Bravia KD43XF7596BAEP - Android no picture
  • Spc.
    • May 2022
    • 16
    • Slovenia
    Greetings everyone.
    I also have Sony Bravia, model:
    Sony Bravia KD43XF7596BAEP - Android.
    What happend is that image dissapeared while we were watching tv.
    Diagnostics:
    1. TV turns on, no errors
    2. Backlight turs on, no errors
    3. Power indicator turns on, white color, no errors
    4. Menu works on android, you can hear sound while switching channels
    5. Volume up and down works via TV remote and via buttons
    6. Tunner works, HEVC / MPEG-4 decoder works
    7. I get audio from channels
    8. No picture is present, but backlight is turned on, not even SONY logo is shown.
    Video:
    https://youtu.be/JaQpQLf8mA4
    What do you guys think happened ? how can i repair it ?
    Do you think it's ribbon cable causing this issue ?
    Thanks.
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sony Bravia KD43XF7596BAEP - Android no picture
    It is necessary to check the voltage on T-con
    • Spc.
      • May 2022
      • 16
      • Slovenia
      Sure, i can check the voltage, just let me know where do i check it.
      T connector ? adapter voltage ?
      19.82V on adapter output.
      • diif
        • Feb 2014
        • 6978
        • England
        There should be a fuse on the t-con, it's under the metal shield in the middle of photo #2.
        • Spc.
          • May 2022
          • 16
          • Slovenia
          I found the Fuse, it is F1.
          Fuse is rated for 60Volts, 7A.
          Fuse is OK
          Fuse to ground gets me 12.4 Volts (average), exact=12.51V
          Image in attachments.
          • Diah
            • Feb 2013
            • 6502
            F1 should messured from both side to chassis 12V. if this was fine.. then disconnect one ribbon cable between the T-CON and panel at time.. see if you have half picture or the other half white color..
              • 12314
              • U.S.
              I suspect tcon, they usually don't cost too much on ebay.
              • Spc.
                • May 2022
                • 16
                • Slovenia
                Yes
                Half White display if i DC one of the ribbon cables.
                Both sides are exact 12.51 Volts of the fuse.
                Can someone link tcon on ebay ?
                • Diah
                  • Feb 2013
                  • 6502
                  your issue not at T-CON, its on MB. i wrote before 4-5 years Sony how they kill TVs if they are connected to Netswork ( Internet ) yours was with internet..
                  try first hard reset. joistic push it and pull it down.. while you plug it in wall.... dont remove untill you have the front LED chaged to green... give time for it it could reboot 2 time
                  • kasfamily
                    • Aug 2014
                    • 774
                    • Russia
                    T-con 6870C-0761A
                      • 12314
                      • U.S.
                      ok, more testing can only help, do diahs testing, if no joy can test the tcon too.
                      • Spc.
                        • May 2022
                        • 16
                        • Slovenia
                        I just did a HR, green power LED, i reseted twice.
                        Still no picture, but the introduction to android music is playing.
                        So the OS is booting normally and working.
                        I again have only backlight and black screen with audio from android introduction.
                        • kasfamily
                          • Aug 2014
                          • 774
                          • Russia
                          It 's not entirely clear - have you tried disconnecting both flat white cables alternately ? Was the image on the screen the same in both cases ?
                          • Spc.
                            • May 2022
                            • 16
                            • Slovenia
                            I disconnected one ribbon cable and i got white black screen.
                            I can also try other ribbon.
                            • Diah
                              • Feb 2013
                              • 6502
                              strange... if the T-CON fault it should not showing half picture white.. such fault need know how & equipment to follow video signal.. this you cant do so only yours option change boards... then go and do invest with T-con as nomoresonys suggested since they are cheap..
                              • Spc.
                                • May 2022
                                • 16
                                • Slovenia
                                Looking at the motherboard, left is left right is right.
                                LEFT RIBBON CABLE REMOVED:
                                WHITE BLACK screen ( see attachment)
                                RIGHT RIBBON CABLE REMOVED:
                                Black screen
                                When i changed both ribons left to right and right to left i don't get White screen anymore.
                                Now it's doesn't matter what combination i use, it's always black screen with backlight working.
                                • Spc.
                                  • May 2022
                                  • 16
                                  • Slovenia
                                  I connected both and restarted tv, now i get white picture.
                                  Everything is working with music playing.
                                  • Spc.
                                    • May 2022
                                    • 16
                                    • Slovenia
                                    I connected both ribbons again, this time in correct order like they were originally installed, left left, right right.
                                    Now i get black screen with sound as in the start.
                                    Could it be one of the ribbons ? maybe due to heat it melted somewhere ??
                                    • Spc.
                                      • May 2022
                                      • 16
                                      • Slovenia
                                      i've tested again.
                                      Final result:
                                      1. Left Ribbon cable removed, while right is connected:
                                      LEFT HALF OF SCREEN BLACK / RIGHT HALF OF SCREEN WHITE (PICTURE ABOVE)
                                      2. Right ribon cable removed, while left is connected
                                      BOTH HALFS ARE BLACK.
                                        • 12314
                                        • U.S.
                                        sounds similar to the nightmare I had/have with the sony xbr900, had the music but no video plus no backlight in my case, read many more different forums, most could not solve it, some solved with new mainboard but a lot of people replaced every board and still didn't solve it, it's a mystery to me, could there be something wrong with or inside the panels or are people just buying bad mainboards, with all these very similar problems, I really think it's going to be one certain thing that's wrong but I CANNOT figure it out.
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • KYBOSH
                                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                          by KYBOSH
                                          Previous owner said TV just went blank one day.
                                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                          I just downloaded the Sony KD-75X7800F Service Manual and...
                                          11-19-2024, 10:12 AM
                                        • lmcancu
                                          Sony Bravia 65x900F BL On but not picture
                                          by lmcancu
                                          I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
                                          I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
                                          10-30-2023, 07:01 PM
                                        • JUCaESAl
                                          Sony bravia KD-65AF9
                                          by JUCaESAl
                                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                          10-20-2025, 04:03 AM
                                        • jason123
                                          Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
                                          by jason123
                                          Hi Folks,
                                          I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
                                          Photos below of the system
                                          The CN6401 Connector has the following vitals:
                                          STBY_3.3V is 3.432 V
                                          BL_ON low (0.153 V)
                                          BL_ERR low (0.051V)
                                          POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
                                          REG12V pins 12.7 V
                                          TCON_VCC12V pins low (0.11V)
                                          TCON_ON low (0.155)
                                          Large caps are at 392V as soon as I plug into power
                                          Seems like a Mainboard...
                                          09-08-2024, 07:05 PM
