Sony Bravia KD43XF7596BAEP - Android no picture
  • nomoresonys
    • 12312
    • U.S.
    #41
    Re: Sony Bravia KD43XF7596BAEP - Android no picture
    @MoreMagnets, when you said you were having same issue, did you mean you were getting the android tv sound but no display?
    • MoreMagnets
      • Oct 2022
      • 16
      Correct. I could hear the menu sounds when pushing up and down on the remote but only had backlight, no image. Tried troubleshooting steps posted in here and got same result as OP with half black, half white and then all black.
      On another note is there a trick to figuring out which pins to block? I thought I had it with pin 1 but must have just been some adhesive blocking another pin temporarily. Got image back on just pin 4 but getting some pretty wicked horizontal black bars.
      Tried checking from the clock output pins to ground with the ribbon cable in and didn't find any shorts so I think this thing may just be haunted.
      • nomoresonys
        • 12312
        • U.S.
        #43
        ok, I meant that spa music you get when the android starts up.
        • MoreMagnets
          • Oct 2022
          • 16
          I get all the normal startup noises, yes. Will start my own thread for further troubleshooting rather than continuing to discuss in OPs.
          Thanks everyone for the advice
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
          • KYBOSH
            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
            by KYBOSH
            Previous owner said TV just went blank one day.
            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
            I just downloaded the Sony KD-75X7800F Service Manual and...
            11-19-2024, 10:12 AM
          • lmcancu
            Sony Bravia 65x900F BL On but not picture
            by lmcancu
            I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
            I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
            10-30-2023, 07:01 PM
          • JUCaESAl
            Sony bravia KD-65AF9
            by JUCaESAl
            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
            10-20-2025, 04:03 AM
          • jason123
            Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
            by jason123
            Hi Folks,
            I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
            Photos below of the system
            The CN6401 Connector has the following vitals:
            STBY_3.3V is 3.432 V
            BL_ON low (0.153 V)
            BL_ERR low (0.051V)
            POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
            REG12V pins 12.7 V
            TCON_VCC12V pins low (0.11V)
            TCON_ON low (0.155)
            Large caps are at 392V as soon as I plug into power
            Seems like a Mainboard...
            09-08-2024, 07:05 PM
