[REPAIR] Help in diagnosing my Old Panasonic Quintrix F TC-21P50R CRT TV
  • sultanpepper
    • Jul 2017
    • 13
    • Egypt
    Hello everyone, I've had this for more than 20 years so it's quite sentimental. It was stored for a couple of years in storage and then we moved to another location and as you can see in the videos this was the surprise. I'm still trying to gather information and watch alot of videos to be as ready as
    I can before opening the back as I am aware there are alot of hazardous areas back inside. BTW I've got the service manual.
    The Problem :
    TV is flickering and colours are not aligned (convergence issue ? ), not all input channels (composite/RCA) act the same and the Component Input acts differently I think. The video will speak a thousand words I'm sure.
    Videos from each input channel
    1- AV1 (Composite cable from a PS1 ):
    https://www.youtube.com/watch?v=6lfxpImx8yE
    2- AV2 (Composite cable from a PS1 ):
    https://www.youtube.com/watch?v=LHWeE9C8_nE
    3- AV3 (Composite cable from a PS1 ):
    https://www.youtube.com/watch?v=x0LMW_M6MHc
    4- DVD (Component cable from a OG Xbox ):
    https://www.youtube.com/watch?v=FgS4MNPdFKM
    TV Model : Panasonic Quintrix F TC-21P50R
    I would really appreciate if any one would help me in sharing his/her thoughts on what are problems I'm having and where and how to fix them that would be really appreciated.
    Background : I'm always looking to learn new things and in my free time I like to buy and fix broken stuff which is quite therapeutic.
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: [REPAIR] Help in diagnosing my Old CRT TV
    Chroma system PAL60 , NTSC ?
    • sultanpepper
      • Jul 2017
      • 13
      • Egypt
      AFAIK It supports PAL60 and in picture settings there ( PAL, SECAM, NTSC4.43, NTSC3.58 & AUTO).
      Where I live PAL was the standard format and our mains voltage is 220V 50 Hz.
      Please let me know if you need more information
      BR
      • sultanpepper
        • Jul 2017
        • 13
        • Egypt
        Re: [REPAIR] Help in diagnosing my Old Panasonic Quintrix F TC-21P50R CRT TV
        please help
        • kasfamily
          • Aug 2014
          • 765
          • Russia
          Does your TV have a scart input
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            Does the PS have an rf module included ?
            • sultanpepper
              • Jul 2017
              • 13
              • Egypt
              Sadly no.
              The TV has:
              1- 3 RCA (Composite) inputs at the back
              2- 1 YPbPr (Component) input at the back
              3- 1 RCA (Composite) input at the front
              4- 1 S-video input at the front
              5- 1 S-video input at the back
              • sultanpepper
                • Jul 2017
                • 13
                • Egypt
                Sadly no
                • kasfamily
                  • Aug 2014
                  • 765
                  • Russia
                  Are you satisfied with the video from the x-box on the component input?
                  • sultanpepper
                    • Jul 2017
                    • 13
                    • Egypt
                    Actually no , the colors are shifted as you can see below
                    • kasfamily
                      • Aug 2014
                      • 765
                      • Russia
                      Is the OSD image on the TV screen normal ?
                      • sultanpepper
                        • Jul 2017
                        • 13
                        • Egypt
                        yes the OSD TV settings menu look 10/10
                        • kasfamily
                          • Aug 2014
                          • 765
                          • Russia
                          Have you tried connecting an xbox to a composite input RCA ?
                          • sultanpepper
                            • Jul 2017
                            • 13
                            • Egypt
                            Hello, Yes I've recorded OG Xbox on composite input RCA as well ,
                            1- AV1 (Composite cable from a OG Xbox ):
                            https://www.youtube.com/watch?v=2LLz_DR7gtM
                            2- AV2 (Composite cable from a OG Xbox ):
                            https://www.youtube.com/watch?v=5HdMMLGjWfA
                            3- AV3 (Composite cable from a OG Xbox ):
                            https://www.youtube.com/watch?v=OxAS3mfC-DU
                            • kasfamily
                              • Aug 2014
                              • 765
                              • Russia
                              Have you tried to change the color mode of the TV using the remote control?
                              • sultanpepper
                                • Jul 2017
                                • 13
                                • Egypt
                                Hello , my apologies for the late response. I've uploaded a couple of photos for the Chassis PCB as per your request.
                                Also I've opened up the TV and took out the Chassis ( Main PCB ) and measured voltage rails and they are very low. Secondary all are very low and the main offline regulator IC I've measured it's Vin Supply and it's supposed to be 16V but its 12-13V and it's fluctuating. Please let me know if you have any ideas I'm at a road block
                                Note: Since I have the service manual, I've used the schematics as a guide but I spent an entire day pulling out suspected components and measuring them ( caps and diodes ) but nothing was out of the ordinary.... please help .....
                                BR
                                • R_J
                                  • 9515
                                  Start by replacing C811 47µf/50v, it is likey weak, I would also replace C826 47µf/160v as a precaution.
                                  • sultanpepper
                                    • Jul 2017
                                    • 13
                                    • Egypt
                                    thanks for the suggestion, I replaced those and alot more at critical areas. Still the same .
                                    BR
                                    • sultanpepper
                                      • Jul 2017
                                      • 13
                                      • Egypt
                                      I borrowed an old VCR and connected it to the RF input and the screen is showing same distorted picture .... any clue what that might mean when all inputs give bad screen ?
                                      Also I've discovered that by hooking up the chassis board back to the crt the voltages readings were good; mainly voltages at the flyback IC were fine and at the secondary windings the voltage regulators outputs were fine as well.
                                      I changed the vertical IC just for kicks but it did nothing .Also I tried recapping around the voltage regulators and the vertical IC .
                                      BR
                                      • mostachio
                                        Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                        by mostachio
                                        Hi Badcaps,
                                        I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                        TV Details:
                                        Model # - TH-65DX700Z
                                        Symptoms:
                                        The television turns on and displays a picture then makes a clicking sound and turns off.
                                        I haven't opened it up yet but...
                                        09-04-2024, 02:32 AM
                                      • Scruit
                                        What is a normal composite signal range for a C64?
                                        by Scruit
                                        Hello all,
                                        Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                                        More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                                        https://imgur.com/gallery/PpqcqPY
                                        My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                                        More detail:
                                        Symptoms are that that I get...
                                        04-28-2022, 05:33 AM
                                      • Andre Gilbert
                                        by Andre Gilbert
                                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                        11-20-2024, 08:52 PM
                                      • AquaMan Ua
                                        by AquaMan Ua
                                        05-17-2025, 09:40 AM
                                      • cloo
                                        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                        by cloo
                                        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                        After doing a factory reset this problem was gone and the picture was back to...
                                        01-06-2025, 06:02 AM
