65UJ654T Backlight but no image
  • nubinator
    • Jan 2012
    • 37
    As titled, just backlight and sound on.
    I disconnect right side TCON LVDS and half screen is white other half just blank. If I reconnect it and disconnect other LVDS whole screen is blank like how I started. Does this mean bad panel?
  • nubinator
    • Jan 2012
    • 37
    Re: 65UJ654T Backlight but no image
    I added pics and took some reading from test points on TCON
    When right side LVDS connected I get
    VIN 13v
    VCC 0.8v
    VGH 0v
    With just left side or no LVDS cables connected
    VIN 13v
    VCC 3.3v
    VGH 28v
    Either way I still get no image on screen. How do I differentiate between bad panel or bad TCON?
      • 12156
      • U.S.
      try the tape cut-off method.
      • nubinator
        • Jan 2012
        • 37
        I tried but always getting low voltages on TCON when right cable connected. I then looked at the panel boards and getting shorts on some of the caps on right side and none on the left. Could bad capacitors be the problem or this just indicative of bad panel? I highlighted the shorted caps in the pics
        • neilc6
          • Nov 2015
          • 1550
          If neither side is providing an image, it is worth trying to replace the tcon board. Maybe find a seller that takes returns.
          • nubinator
            • Jan 2012
            • 37
            wow I took the 4 caps off the panel board that were showing short I tried without replacing them and now i got full display and seems to be working fine? what do those caps do? it was only c320 that was actually bad and i ripped up a couple of pads trying to desolder the little things
              • 12156
              • U.S.
              ok, if short is gone, then it was just a bad cap, I should have said check the caps first. I would replace the bad cap. Maybe look on youtube for pad repair or a similar solution.
                • 12156
                • U.S.
                https://www.youtube.com/watch?v=xty1G5UBYb0
                  • 12156
                  • U.S.
                  https://www.youtube.com/watch?v=SaBwdJLFVPU
                  • nubinator
                    • Jan 2012
                    • 37
                    Thanks luckily It was only ground pads I lifted so was able to just bridge to adjacent cap.
                      • 12156
                      • U.S.
                      ok,
                      • Constantinos
                        Macbook Pro A2442 820-02098 No image but has backlight
                        by Constantinos
                        Hi all
                        I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                        He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                        Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                        Obviously, he decided against this and gave it to me so that I could have a crack at it.
                        From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                        08-24-2024, 09:48 AM
                      • ajgae
                        HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                        by ajgae
                        Hi everyone!
                        First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                        03-06-2025, 09:53 AM
                      • learnmore
                        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                        by learnmore
                        Hello Community!
                        CASE DETAILS
                        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                        Tried inserting firmware on USB and left it in for a few hours, but no change
                        03-03-2024, 09:49 AM
                      • prw07
                        A1398 2015 820-00426 No image and display backlight before log in on macOS
                        by prw07
                        Image and display backlight are present while macOS is load but the display turns off before log in. The laptop is working (hear sounds), but without image and backlight. Internal LCD normal is worked in safe mode also when connect external LCD.
                        I think the problem is with the integrated graphics iGPU.
                        Is it possible to disable iGPU ?...
                        12-19-2023, 11:26 AM
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
