LG55UK6950PLB backlight but no picture
  • Chrissygizmo
    • Mar 2021
    • 145
    • United Kingdom
    I've got an LG55UK6950PLB, I have backlights but no picture, I've read about AVDD 17v in another thread on here, I've messed around blocking lines , previously I had only 17v on the left side with the left LVDS connected and 3.9v on the right, now since blocking lines I've got 17v on both sides but no sign of a picture yet.
    I would be grateful for any help as this one is doing its best to psssssi me right off lol
  • Chrissygizmo
    • Mar 2021
    • 145
    • United Kingdom
    Re: LG55UK6950PLB backlight but no picture
    Quick update, I've got a picture now but half of the screen is slightly darker
    • notallbad
      • Oct 2012
      • 1190
      How did you manage to get a picture?
      Have you checked the tab bonds for obvious damage i.e burnt out?
      Think I had that issue too, screen darker on one side due to tab bond. Was able to get brightness back luckily, believe it was caused by a short.
      • Crew
        • Jun 2015
        • 4
        • Csongrád
        Hi! How could you make it work? I’ve got a TV with the following issue:
        If I remove left cable, I can measure VCC, VDD etc voltages on the right LCD board. If I disconnect right cable, and only left cable is connected, I can not measure any voltage on the left cable.
        More interesting, I tried the “tape fix”. I covered CK lines One by One and all together too, but No changes. Do you have any tip for furthet fixes?
        • Crew
          • Jun 2015
          • 4
          • Csongrád
          Additional info:
          If I disconnect the left ribbon I can measure VCC, VDD on the right side, but IC800 is getting very hot. It's an i-2111 J824 IC. What it does? Has anybody info about it?
          • lotas
            • Jan 2016
            • 4805
            • Russia
            i2111 - High-Current VCOM Drive
            Op Amps for TFT LCDs (IML2111CL-TR ( MAX9650 = ICN7211 = ANX7011))
            • Crew
              • Jun 2015
              • 4
              • Csongrád
              Lotas, thanks the schematics!!!
              Based on them I could disable the IC800 / i2111.
              ( removed the resistors before and after this IC. R801, R820 )
              It seems, that I still have a short on HAVDD line. I removed the big cap from this line ( C806 ), but the short is still there.
              Do you have any additional tip for the repair?
              • lotas
                • Jan 2016
                • 4805
                • Russia
                C807 is also on the same line as C806 (maybe other capacitors located elsewhere, or maybe in the panel itself ...).
                • Crew
                  • Jun 2015
                  • 4
                  • Csongrád
                  It seems that the panel itself is faulty
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • noisykid
                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                    by noisykid
                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                    12-30-2024, 07:15 PM
                  • groomit
                    Philips 50PUS7363/12 Backlight but no picture
                    by groomit
                    I'm having trouble with above mentioned TV. Bought it defect.
                    Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                    Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                    I can see backlight, but screen stays black.
                    What I've tried:
                    - Disconnect right side cable from T-Con -> same (backlight but no pic)
                    - Disconnect left side...
                    11-22-2024, 02:43 PM
