UE46ES6100 and UE55ES6100 MainBoard Compatibility
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    HI,
    I am after a replacement board for U46ES6100 BN94-05898A . I came across one for UE55ES6100 BN94-05678Z looks identical including the LVDS connector.
    Anyone been here?
  • nomoresonys
    • 12331
    • U.S.
    Re: UE46ES6100 and UE55ES6100 MainBoard Compatibility
    if you left out the E in U46ES6100, so if it should read UE46ES6100, then It should work.
    • bohaboha
      SAMSUNG MAINBOARD COMPATIBILITY BN41-02751B
      by bohaboha
      Hello everyone, hope you have had a lot of sun and a nice summer.
      I wonder and hope that these two Mainboards are compatible because they look like twins. one Native is BN41-02751B.000 and the same thing on the other printed on the circuit but they differ what is on the stick Native BN94-16627N the other BN94-16103q. don't know if the region issue can cause problems
      or maybe it's a dump question or even a settings question for them to fit
      is there anyone here who can help me sort out this question very thanksm...
      08-04-2025, 05:42 PM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • korn88
      Dead LG OLED55BX
      by korn88
      Hi all! I'm learning so please be patient with me.
      My LG OLED55BX decided to not turn on anymore after a bit more than 3 years. I've read the forum quite a bit and have done some basic troubleshooting, but I’m stuck and need help with the next steps.
      Symptoms:
      I turn on the TV and hear 1 relay click. Stand-by light blinks, light can be seen in optical connector, no image on screen and 3-5 seconds later another relay click sounds and TV turns off.
      What I've tried so far is:
      • Disconnected lower LVDS cable -> Optical connector light stays red, no second
      08-13-2024, 04:23 PM
