Hisense 65H6570F Logo shows then turns off
  • USmechS
    replied
    Re: Hisense 65H6570F Logo shows then turns off
    Originally posted by Diah
    for recovery try TV plunged out from wall.. press and keep press power on the TV after first 5 second plug the tv in wall and keep pressing power on TV 15-20 second until you have recovery on screen.. this method used for android TV which it had only power button on it.
    you may try it several time
    This did not work, no picture or BL or power LED flash or anything. tried multiple times, both with the TV power button (remote batteries out) and with remote. Tried holding the TV power button after plugging the TV too, the original issue of logo happens. Tried holding the remote power button after turning the TV on, same issue.
  • USmechS
    replied
    please don't do any things at this time.. could be dskall thought are correct... however hisense said up to 16Gb but use 4Gb or less will be better with format Fat32 MBR. and insert it at USB V2 (black ) port in the tv not the ( blue ) one V3.
    also because yours TV Android which you didn't mentioned about at yours first post... i went in method of vidaa system. so no need to rename.. and use the exact instruction the service send to you..
    if the tv didn't accept the firmware after this change.. it could be yours android version the last one.. just contact service and they will send you another recovery firmware.
    this why we encourage all when the post to write full information on the tv. as small hiding info will drive us to wrong direction.
    I apologize for not mentioning the android TV part.
    I tried a 2GB fresh formated FAT32 MBR mode. Same results. BL on one power LED flash no picture, restart, BL on one power LED flash, restart, BL on some purple line sections flashing and moving up and down one power LED flash, repeat.
  • Diah
    replied
  • Diah
    replied
  • USmechS
    replied
    I do not have any instrument to check the voltages now, That need to be tomorrow. I appreciate it if you can walk me through how and where I need to check for various issues (BL, Logic board, Power board, etc.)
  • USmechS
    replied
    These are the pictures of the boards.
  • USmechS
    replied
    If it is any help, The power LED light on the tv starts as ON when the TV os OFF, when I turn the TV ON, the power LED light turns OFF, then flashes 2 times before the TV turns off and the power LED light goes back to ON. It tries to do the 3rd flash, but in the middle of it it TV turns OFF and power LED light goes back to ON.
    replied
    yep, time to take the back cover off and give it a good looking over and voltage testing, seems like backlight issue.
  • USmechS
    replied
    you should have joystik not only one button.. mean it can be pressed and push down or up or to side..
    It just does not have any joystick, or any other button. I have checked all parts of it.
  • USmechS
    replied
    every sytem of TV has had his own way to handel HW failure.
    if all what i worte didnt help you need to open the cover and provide good pictures focused high res on the power boards and the BL socket, and any voltage print layot u could fine on PCB
    You are helping immensely. How do I do inter recovery mode ?
  • Diah
    replied
    Originally posted by USmechS
    There is only a physical power button
  • Diah
    replied
    I had a Samsung TV where BL LEDs died. It shows picture but no backlight at all. If I put a flash light to it I can see picture. That has been my experience with BL. This is why I am asking.
  • USmechS
    replied
  • USmechS
    replied
    hold on.... yours Hisense are android system.. not vidaa one... try inter recovery mode if you did and it show on the screen mean urs BL ok. then you need to clear cashe and then do factory reset
    Yes, it is android TV. How do I do inter recovery mode ?
    BTW, there is no reset pin or hole or anything.
  • Diah
    replied
  • USmechS
    replied
  • USmechS
    replied
    PQI what this mean ??? are you using windows
    BL come for just 1-2 second didnt mean they are healthy. its BL issue not Mainboards at all.
    PQI is the name of the manufacturer. I am using Windows.
    How do I check if the BL is the problem?
  • Diah
    replied
    It is in MBR mode. It is 8GB, I think it is USB 1.0, definitely not USB 3.0.
    The Hisense Logo shows up, and the backlight turns on (both for a few seconds), is it an LED backlight issue or logic board issue?
  • USmechS
    replied
    if the USB stick are MBR mode formasted FAT32 and the file on it in name upgrade_loader.pkg and it didnt work to have screen of upgrade prosees... mean yours TV went to shut down as it had HW issue 100% are led backlight, one or more are defect.
    with hisense vidaa no problem with the usb drive size, i have 64Gb MBR mode Fat32 many hisense firmware for diffrent model on it, the one i need just to rename it to upgrade_loader.pkg
  • USmechS
    replied
    the rename supject of the file must be 100 done. what kind of stick you have ??? stick should be MBR mode
    shoe me the properties of yours usb stick and the file inside it
  • taslan
    Surface 7 Pro wont boot, shows Logo and immediately turns off
    by taslan
    as stated in the title, my surface 7 pro wont boot anymore.
    When i press the power button it shows the square windows logo for a second and immediately turtns off again.
    I dont even have a chance to get into bios or boot from usb.
    While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
    I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
    Bought it directly from microsoft and used it now and then and only...
    01-16-2025, 01:25 AM
  • IIOSOH
    46PFL5507K/12 - Shows a "Hourglass" logo then turns off the backlight - No sound
    by IIOSOH
    I'm trying to fix a Philips TV [46PFL5507K/12] for a friend. A few seconds after turning it "ON" a hourglass appears and stays on the screen for around a second, then the screen goes black again, there is no picture nor sound when i connect via HDMI to my PC.
    I've opened it up and took a few measurements, but i can't seem to find the correct schematic for this exact model. The official service manual has detailed schematics and info for pretty much every other TV from the series but just some generic information about this exact part number so i measured...
    04-02-2022, 12:43 PM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • EazyBone
    Hisense 55H8F Emmc programming help
    by EazyBone
    I am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
    I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
    1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
    2) In the options section point number 2 operation says "30...
    06-11-2024, 06:03 PM
  • TheQuentincc
    Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
    by TheQuentincc
    I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
    06-26-2025, 01:44 PM
