I have a desire to keep this one out of the land fill awhile, so I found the 5vdc stdby circuit gone to cold ground. There is no stdby light on the front and of course has no display or BL. The main caps have 168 vdc. There are no voltages on any of the pinouts. The power board at issue is model 056.04224.0021, and the suspected removed diode DM856 has full continuity in both directions in and out of circuit. After its removal, the 5vdc stdby pin no longer shows shorted. Can I substitute a SR506 for the defective SR206522Y that came out (the fuse that protects the IC nearby is 2A), if not what?? There is no physical damage that has been discovered. The LED BLs have been tested and are fully functional and the screen is not cracked. What are the likely components that this failure has affected, other than the usual DM853 - DM855? Thanks guys.
Vizio D65-D2 part substitute
Tags: None
Re: Vizio D65-D2 part substitute
Thanks for the help.
The fuses are not open, the icb801 is labeled 2A153D, SK592, G14AI I wonder how I can test it.
Ok, this is going to be wild, since the DM853 thru DM855 (SR515) are in parallel, could I take the DM853 out and place it into the DM856 (SR206) temporarily to see if the 5vdc circuit come up?
What might have caused this DM856 to short? If I put another in, could it short for what reason?Last edited by captainKKK; 04-24-2022, 08:25 AM.Comment
Diodes in parallel are a bad idea. Sometimes one works harder than the other one and the inevitable happens. As long as there is no load on the 5v you can try the smaller diode no problem to see if the 5VSB comes up. However don’t turn the tv on as it probably will exceed the rating of the diode.Comment
Diodes in parallel are a bad idea. Sometimes one works harder than the other one and the inevitable happens. As long as there is no load on the 5v you can try the smaller diode no problem to see if the 5VSB comes up. However don't turn the tv on as it probably will exceed the rating of the diode.
"The 2A153D IC has VCC at pin 2 and Ground at pin 3.
With TV unplugged:
Measure for a short between pins 2-3.
In fact, measure for shorts between pin 3 and all other pins of this IC."
My 2A153D IC has very low or no resistance between pin 3 and 2, but his must have had the same.
I borrowed an SR260 from another board I have and soldered it in. I cannot find the RB801 fuse R_J referenced therein.
Caution to the wind and nothing else found, plugged in the PS board by its self and the 5vsb appeared. Jumped the PS_On and the 12vdc appeared but did not get to check the main caps voltage.
Working on PS and MB installation and cable up, going to smoke test it very soon after lunch........badcaps forum are the best......Comment
I cannot find the RB801 fuse R_J referenced thereinCan I substitute a SR506 for the defective SR206522Y that came out (the fuse that protects the IC nearby is 2A),
If the fuse IS open, check the resistance between pins 5~8 and pin 1 of the ic, this will check if the internal mosfet is shorted.
I would as a precaution replace the two caps CB802 & CB803 in the primary, these are likely for the vcc of the ic.Last edited by R_J; 04-24-2022, 02:18 PM.Comment
Thanks R_J, I interpreted your post wrong about the RB801, since it is a resistor. I will remember your concerns about CB802 & CB803 if it fails again because it is already completely reassembled and working perfectly. It is burn in now so if you do not here any more here, this is a done deal. WE saved the Planet again.Comment
Update: Still going strong, working perfectly and beautifully. No hiccups or deficits. Super bright on only 30% bl. And the smart apps are awesome. I am hooked.Comment
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by howardc64Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot.... - Loading...
