Samsung UE50J6150AS BL_TON OK Screen only little corner lighting up
  • Diah
    • Feb 2013
    • 6564
    i got this TV today.. as you can see the screen LCD had only at the corner lighting up, the other round light spot are lens falling down on LED as i can hear it when i move the TV.
    i tell the truth i never seen this before.. LED BL yes are little blue but i don't thing it related to this issue as i suspect the T-CON, i saw before T-CON when it work the 2 blue LED on it will lit on.. here only one. even i tested the led and its fine.
    voltage on T-CON F1 from both side for me little high 12.55V ( could be indicated open / not complete operation on the T-CON.
    disconnect one ribbon at time no any white half screen only corner spot will disappear when i unplug the ribbon on its side. so it tell me this is from LCD the sport was not from BL
    disconnect the BL socket from PCB and turn on... it turn on only no BL
    disconnect the MB from PCB , BL come one at same level when they work at time
    i feed HDMI signal and hearing the sound and BL level change regards the video sync. no sigm on any picture on screen
    any one have this issue before or read on it.. please remember this tv had no Internet LAN or WLAN. and beside the blue of BL option to replace T-CON are out from the table.
    thanks.
    • 12330
    • U.S.
    Re: Samsung UE50J6150AS BL_TON OK Screen only little corner lighting up
    not sure, but a guess is being a samsung, could be most of the backlights are bad.
    • dskall
      • Oct 2016
      • 2905
      • usa
      You may have several problems. I would sort out the light problem first. Panel or diffuser
      • Diah
        • Feb 2013
        • 6564
        thanks for the response.. yes i agree. 3 fault i can tell
        1- blue LED BL easy
        2-T-CON toasted only VDD VCC read fine. VCOM wirh out ribbon connected 0V with ribbon -1.40 VGH less than 2V
        3- Panel shorted which toasted the T-CON.
        will keep it aside for the future if i my hand got on T-CON or to try the panel for different system.. lol.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Would be interesting to find out what is causing that bright spot in corner. All LEDs are lighting up?
          • Diah
            • Feb 2013
            • 6564
            yes all lighting, only one LED lost the lens and found it under the hard reflector
            bright spot at corner are just view LCD cells turning on.
              • 12330
              • U.S.
              Hello Diah, have a quick question, do you know how to jumper this power supply as stand alone, I can't quite figure out how to jumper the smaller connector cnl803 with the a-dim and p-dim, on/off, gnd, e_sync pins, thanks: power board https://www.shopjimmy.com/samsung-bn...w-963288019440
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                by JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                Please help. Thanks in advance!
                08-12-2025, 11:45 AM
