Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    #101
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    With jumper wires on:
    PD-15 (BU5V) ----- 14 PS_ON ( turn on UR13.2V )
    PD-15 (BU5V) ----- 16 PNL_POW (turn on PNL12V )
    PD-15 (BU5V) ----- 24 (STB) ( turn on BL_ on ) IC7700
    PD-15 (BU5V) ----- 21 OFL
    *PD-15 (BU5V) ----- 19 Dimmer (983ohm resistor)
    PD Connector:
    PD-1 (PNL12V) : 11.92V
    PD-2 (PNL12V) : 11.92V
    PD-3 (SGRN) : 0V
    PD-4 (SGRN) : 0V
    PD-5 (UR13.2V) : 13.05V
    PD-6 (UR13.2V) : 13.05V
    PD-7 (UR13.2V) : 13.05V
    PD-8 (UR13.2V) : 13.05V
    PD-9 (SGRN) : 0V
    PD-10 (SGRN) : 0V
    PD-11 (SGRN) : 0V
    PD-12 (SGRN) : 0V
    PD-13 (AC_DET) : 3.27V
    PD-14 (PS_ON) : 4.95V
    PD-15 (BU5V) : 4.95V
    PD-16 (PNL_POW) : 4.58V
    PD-17 (NC) : 0.04V
    PD-18 (NC) : 0.04V
    **PD-19 (DIMMER) : 4.55V**
    PD-20 (NC) : 0.04V
    *PD-21 (OFL) : 1.74V*
    PD-22 (ERROR) : 0V
    PD-23 (NC) : 0.04V
    PD-24 (SBY) : 4.3V
    Added PD-15 to PD-19 with 983ohm resistor and read 4.55V, and value of PD21 changed from 0V to 1.74V.
    Still the same - screen flashes for a split second then off.
    • lotas
      • Jan 2016
      • 4765
      • Russia
      #102
      These SHAPRs have bad contacts (connectors) on the LED strips (you need to solder them)
      • Diah
        • Feb 2013
        • 6449
        at this moment i wouldn't care of this since PD-22 (ERROR) =0 V mean no error.
        MB signal are not only V. its pules freq. we can see there are several pins need signal..
        i never read some one successfully to run the BL on at this PCB all are one click.. one things more this BL had nothings to do with main fault.. because MB just one signal send PS_ON no other signal as the cpu communication failed.
          • 12284
          • U.S.
          #104
          the mystery deepens, lol.
          • Diah
            • Feb 2013
            • 6449
            good points... OP need to dive deep to see whats going on this second blink..
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #106
              So I re-soldered all the pins of L1 and L2 connectors.
              Some of the pins has got tiny bubbles when heated up, not sure if those are signs of bad contact?
              But now it doesn't flash at all... Value of OFL changed from 1.74V to 0.8V, all others remain the same.
              • Diah
                • Feb 2013
                • 6449
                check again yours soldering work that no short between pins...
                remove the dimmer jumper they will flash again
                wait for yours MB.
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  #108
                  wait for yours MB.
                  Cleaned up my shoddy act on L1 & L2, and Tada - BL ON!! Such a beautiful sights!!!
                  Thank you every one - your guys are magicians to me
                  And yes sir - waiting for my MB.
                  • Diah
                    • Feb 2013
                    • 6449
                    so you can sleep today on the screen light LOL
                      • 12284
                      • U.S.
                      #110
                      VERY nice, mystery solved.
                        • 12284
                        • U.S.
                        #111
                        I was pretty sure I saw this model with forced on backilghts on some forum somewhere.
                          • 12284
                          • U.S.
                          #112
                          well I should have mentioned checking the solder joints, I guess I preach it so much I just assumed I already did, I must be slipping.
                            • 12284
                            • U.S.
                            #113
                            This was a very good clue too, the first part that is. lol.
                              • 12284
                              • U.S.
                              #114
                              Knew there was something wrong on powerboard side, NEVER saw on you couldn't turn on.
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #115
                                After a good night sleep rejoicing the romantic backlight, we thought of summarizing which PD pins must be jumped in turn on the BL. So a created a matrix, and start testing each combination.
                                To my horror - none of the combinations work and no more BL!!!
                                After several trial and errors - all jump wires are with 850ohm resistor, and only one with 983ohm, and it turns out, PD-21 OFL on only work with this 983ohm resistor, not the 850ohm ones!
                                Also, PD-19 Dimmer is not necessary for this work on also.
                                  • 12284
                                  • U.S.
                                  #116
                                  ok, interesting, was wondering what combo was needed.
                                  • beetle1303
                                    • Jul 2019
                                    • 279
                                    • Singapore
                                    #117
                                    While waiting for MB, I was googling for a Sharp TV boot sequence/hand-shaking, but did not find a complete documentation.
                                    This is what I guessed based on the conversions:
                                    1) Powered up - PD15 BU5V gets 4.96V to MB
                                    2) MB send PD24 STB 4.7V, turns on red standby indicator light
                                    3) Pressed power button, MB sends PD14 PS_ON 4.95V to PSU
                                    4) PSU turns on PD5-8 UR13. 2V 13.05V, and sends PD13 AC_DET 3. 27V to MB
                                    5) MB sends PD16 PNL_POW 4.58V to PSU
                                    6) PSU turns on PD1-2 PNL12V 11. 92V
                                    7) MB sends PD19 Dimmer 0.14V and PD21 OFL 4.16V
                                    8) PSU turns on BL!
                                    Besides obviously more and various checks and sensing for and between each step, is this close enough, or far from being correct?
                                    • Diah
                                      • Feb 2013
                                      • 6449
                                      poists 2, not exactly, becuase the LED indicator connected to MB not PCB, and the first points when PCB send BU5V this will be used to LED indicatore and to start the SPI Flash.
                                      i thinl STB they mean start BL circuit. because other to tuen on 13 and panel 12 are clear.
                                      any way. its good if you rework the socket on MB take it out clean the solder and resolder it again correct... who knows could we have different sign. since LED BL worked after rework soldering then do it on the MB socket too.
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #119
                                        So not surprisingly, after re-soldering the PB connector on the MB side - no indicator lights, power backlights, nothing..
                                        Anyone has any document or reference to Sharp booting sequence/hand-shaking protocols? I personal feel this would be a very help guide on focusing problem solving on Power Board first or Mainboard first.
                                          • 12284
                                          • U.S.
                                          #120
                                          well it was working, then you messed with the mainboard connector, I think you tried to over-fix it, not good, maybe same as before re-check your work.
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • koby058
                                            yoga9 3v3 5v fluctuating
                                            by koby058
                                            Hi
                                            board model: NM-D992
                                            type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                            main power rail voltage 13v
                                            till now i have tried:
                                            measured all coils resistance looks ok
                                            replaced RT6585CGQW to a brand new one
                                            replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                            happen both on DC power and on battery
                                            issue remains
                                            video
                                            schematic attached...
                                            08-03-2025, 09:06 AM
                                          • madan1
                                            DALI SUB E-12F class D, fluctuating power rail
                                            by madan1
                                            Good day everyone.
                                            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                            The normal value of the positive and negative power rails is +/- 43V.
                                            The positive rail stays...
                                            Yesterday, 10:33 AM
