RCA LED46C45RQ,Sound but no Back lights
  • tennno`
    • Nov 2013
    • 37
    • usa
    Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
    Has All voltages coming from main board.No voltage going to
    Back lights from power board.Have no Schematic.Back lights work when
    Led Back light Strip tester is used.Tester shows 110 volts from each
    side.Also if you use the side controls and use the vol +or- tv shuts
    down.
    Thanks for any help
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sound but no Back lights
    You have 0v at led connector when you power on?
    • neilc6
      • Nov 2015
      • 1550
      Your LED tester may not detect the bad LEDs since it runs at much lower current than the TV.
      Every RCA LED TV I've encountered had bad backlights if it turned on with no backlight or flash of backlights. Impossible to get new LED strips for them so I repair the individual LEDs and turn down the backlight level as low as possible in the service menu. Menu-1-1-4-7 or source-2-5-8-0 under panel settings. I've encountered models where lowering the backlight didn't save or I couldn't adjust it with the remote cursor buttons. Some do have energy savings picture mode which run the backlight a little lower than max.
      • tennno`
        • Nov 2013
        • 37
        • usa
        Yes 0 volts
        • tennno`
          • Nov 2013
          • 37
          • usa
          When tester is put on back lights ,It lights in full Brightness-no dark spots. Picture Perfect
          • dskall
            • Oct 2016
            • 2905
            • usa
            So power board is bad. Need to check components in led circuit.
            • tennno`
              • Nov 2013
              • 37
              • usa
              I can't find a LED46C45RQ Schematic (RCA)
              • dskall
                • Oct 2016
                • 2905
                • usa
                Re: RCA LED46C45RQ,Sound but no Back lights
                Need good pictures of boards.
                • tennno`
                  • Nov 2013
                  • 37
                  • usa
                  Hope this helps
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    And you are getting your BL_ON voltage? Need to check ds2 and ds2a for shorts. Also need one good picture of whole back of board.
                    https://www.shopjimmy.com/rca-re46hq...ply-led-board/
                    • tennno`
                      • Nov 2013
                      • 37
                      • usa
                      Took ds 2 and ds 2a out of circuit , checked good also Qs7&9
                      • R_J
                        • 9633
                        down.
                        Thanks for any help
                        So you have the BL_ON voltage for sure?
                        • tennno`
                          • Nov 2013
                          • 37
                          • usa
                          FYI Just got new board installed it and the same thing happening
                          • R_J
                            • 9633
                            Which board? Power supply? Main?
                            • tennno`
                              • Nov 2013
                              • 37
                              • usa
                              Power supply
                              • R_J
                                • 9633
                                I suspect you are not getting the BL-ON voltage from the main board to turn on the back light circuit
                                • tennno`
                                  • Nov 2013
                                  • 37
                                  • usa
                                  Also I noticed that when tv starts up I get voltage at connector going to back light and then the voltage drops off (new board)
                                  • R_J
                                    • 9633
                                    What does the BL-ON voltage do on CON4 when the tv is first turned on? does it stay the same level when the backlights are on and then turn off?
                                    You likely have a bad led in the panel. one bad led will trigger the backlight protection circuit to shut down.
                                    • tennno`
                                      • Nov 2013
                                      • 37
                                      • usa
                                      got 5 v sb rest dead turn on tv got all voltage that are supposed to be there 12v 5v etc.
                                      • tennno`
                                        • Nov 2013
                                        • 37
                                        • usa
                                        Will tear it apart and see.
                                        • JohnML1975
                                          Samsung UA50TU8000W no picture and no sound
                                          by JohnML1975
                                          Hello All
                                          have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                          TV will not turn on
                                          There is no standby light
                                          When I press ON button for remote the red standby light does flash but no picture and no sound
                                          From the back of the TV I can see the red light on the back of the mother board
                                          Holding torch to the screen I cannot see a picture
                                          I removed the back cover
                                          Observing the boards I cannot see any damage
                                          I disconnected the main board from the power supply
                                          the back...
                                          08-30-2025, 09:40 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                        • Musictuff
                                          70UH6350 Back lights
                                          by Musictuff
                                          My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                          04-09-2023, 11:45 AM
