Eprom dump versus firmware update
  • angelos
    • Dec 2012
    • 573
    • South Africa
    I have a interesting question but does anyone know the following.
    If i flash a tv with a firmware update and then i remove the memory ic 25Q32BVSIG, a 4mb SPI chip and read the contents with my programmer and compare the two image files (Dump versus firmware) are they going to be identical.
    What I want to get at is that if I have a firmware update and I try to download it directly into the SPI chip will it be successful? Will it work. So far I never tried it because I assumed it will not be the same. Anybody know?
    Regards
    Angelos
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Regards
    Angelos
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Re: Eprom dump versus firmware update
      Firmware updates are different from the content on the 25Q32. It wouldnt work if you put the firmware directly on a 25Q32 or vice versa.
      • angelos
        • Dec 2012
        • 573
        • South Africa
        I thought as much. Thanks for confirming my suspicion.
        Cheers
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4552
          • Italy - Milan
          i think you forget some "?", can you repeat? Anyway an update is almost never the same as a dump, because an entire firmware is comprehensive of every partition , the boot loaders (preboot, boot, etc..), the kernel, system, recovery, etc., an update can be only the main software update..
          • angelos
            • Dec 2012
            • 573
            • South Africa
            Yes Davi, my grammar sucks. My english teacher thought so too. ��*♀️
            Over the weekend i got in a tv that needed a eprom dump and i could not fix it because the unit i was working on is so uncommon.
            • Tamo Neko
              Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
              by Tamo Neko
              I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
              What Happened:
              I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
              • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
              • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
              What I Need:
              • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
              02-12-2025, 11:29 PM
            • jorpec
              Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
              by jorpec
              Hi, all
              I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
              10-17-2025, 03:51 AM
            • Mephysis
              DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
              by Mephysis
              Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
              I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
              03-27-2025, 02:34 AM
            • gun4as
              Need firmware dump for LG 23MP48HQ-P
              by gun4as
              Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
              08-25-2025, 04:28 AM
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
