I have posted this problem but it appears worse. I have a great picture but this huge vertical bar down the right side. This is not under warranty and I was wondering where to look for the problem or is it something that can be fixed? I though it might be a loose connector but I checked them and reseated.
NEC TV Vertical Line
Re: NEC TV Vertical Line
Originally posted by davgI have posted this problem but it appears worse. I have a great picture but this huge vertical bar down the right side. This is not under warranty and I was wondering where to look for the problem or is it something that can be fixed? I though it might be a loose connector but I checked them and reseated.
It's obvious that the red driver (buffer?) for one column is not working. I THINK that those are on the flex strip that connects the tcon to the panel, and are not repairable.
Again, trust Wizard's diagnosis.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
by otaku_nutHi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...08-19-2025, 06:11 PM
by TrueSword88Hi all.
I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
The line just happens to coincide with the end of COF and start of the next COF (attached).
The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
Hoping to fix... -
by almarhumHas one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...-
by mrsithHi.
Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's... -
by bdalkiranDear All,
I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
Please advice how to proceed and what is the... - Loading...
