Sony KDL-55EX500 solid green screen
  • Nopy
    • Mar 2022
    • 4
    I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
    My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green intermittently. I tried heating up the T-con board with a hair dryer for a bit and that seemed to resolve the problem for a day, but the next day the green screen came back, which has me wondering if it's a bad solder joint or bad lvds connection.
    Any advice/confirmation on pinpointing the issue would be appreciated. I saved this tv from someone who was taking it to the dump so I'm trying not to spend much on it. I do apologize if I got any part names wrong. I've never fixed a tv before and can count on one hand the number of electronics I've fixed in my life.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-55EX500 solid green screen
    I would say you need to concentrate on your cable between t-con and main board. Any damaged contacts. If you can clean contacts.
    • Nopy
      • Mar 2022
      • 4
      I gave this a try today and cleaned the cable ends and connectors on the T-con board and main board with rubbing alcohol. The intermittent green screen still shows up.
      I did find one solder joint on the T-con that looked cracked so I added more solder but that didn't help either.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would try wiggling cable and moving connectors. Taping on t-con and main board to see if anything changes. Should be able to narrow an intermittent down.
        • Nopy
          • Mar 2022
          • 4
          I’ve tried wiggling the cable/connectors and when it seems like it’s working, the screen goes green again later on. What do you mean by taping? Like just securing it with tape?
            • 12274
            • U.S.
            I think I would throw a new tcon at it.
              • 12274
              • U.S.
              this one looks like a match, need to match up the numbers on the white sticker as described there in the ad if you get one: https://www.ebay.com/itm/15254981916...Zh5NG#shpCntId
              • jimjoe123
                LCD TV Green/Pink screen problem
                by jimjoe123
                I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                Then each time...
                02-23-2020, 01:29 AM
              • kokos
                LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
                by kokos
                Hi ! to all fellows out there!
                I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
                I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
                The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
                I tried connected the lan and I can seee TV via local lan (as a device I...
                02-26-2024, 10:48 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • String2016
                samsung np300e green screen
                by String2016
                I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                07-26-2025, 04:00 AM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
