Samsung T22b300 power supply problem
  • sempre
    • Nov 2020
    • 21
    • Italia
    Hi I'm trying to repair the Samsung lt22b300 power supply. I replaced the srtw6052 chip that was shorted together with the blown fuse and a blown 222 1kv capacitor.
    Now if I check the output voltages they all seem ok, but as soon as I connect a load, led or mainboard, all the outputs become oscillating (backlight flashes).
    To rule out problems with the LEDs or the main board, I tried to replace the power supply board (PD23A0Q) with a borrowed one from another working TV and everything works regularly.
    I checked all the diodes and non-smd capacitors both with the curve trace and by disassembling them and I have not encountered any problems. On the soldering side, I checked the smd diodes in the area of the strw integrated circuit and I also found nothing there. Please I would like to know if someone has solved a similar fault and if you can advise me how to proceed.
    Thank you
    Edoardo
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung T22b300 power supply problem
    Did you also check the main cap?
    • sempre
      • Nov 2020
      • 21
      • Italia
      Yes, thanks for the reply, I checked that too.
      • R_J
        • 9535
        Replace CM807 and see if that fixes it. Also Remove one end of RM803 (0R35Ω2w) and check DM803 in case it is shorted.
        • sempre
          • Nov 2020
          • 21
          • Italia
          Thanks for the reply.
          I first replaced rm803, (I used a 0.39ohm) because it seemed slightly cracked, the measured value was still correct.
          When I removed the resistor, I could check the diode dm803 (with the curve tracer) and it's ok.
          I have powered the board and connected only the leds and there is always the same problem.
          Then I replaced the 47uF capacitor next to the strw ic and the 1200uF and 100uF 100V capacitors.
          Nothing has changed.
          I tried to attach an animated gif but I couldn't (now is attached as a zip file).
          Any other ideas on how I can proceed?
          Greetings,
          Edoardo
          • dskall
            • Oct 2016
            • 2905
            • usa
            What voltage are you getting on main cap?
            • sempre
              • Nov 2020
              • 21
              • Italia
              300v
              • dskall
                • Oct 2016
                • 2905
                • usa
                Does this board have PFC? Without pictures and voltage readings it's hard to help.
                • sempre
                  • Nov 2020
                  • 21
                  • Italia
                  Thank you for your reply.
                  In this board there are mainly 5v and 13v for the main board, and 58v for the leds. When there is nothing connected I find the voltages at the right value. When I connect a load, they oscillate and (the 5v goes down to 0 then back to 5).
                  I redid the reading on the 100uF 450V capacitor and there are between 295v and 297v. I noticed that these values drop by a couple of volts when I connect the main board and the leds, the reading fluctuates a little.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    So you replaced icm901s? You have checked all caps. resistors and diodes in that area? What is your ac voltage into the power board?
                    • sempre
                      • Nov 2020
                      • 21
                      • Italia
                      I replaced icm901s, the 220pF 1kV capacitor and a fuse, all shorted or blown.
                      Next I checked and replaced rm803 and two capacitors one on 5V another on 58V.
                      The TV is powered at 220vac
                      • lotas
                        • Jan 2016
                        • 4601
                        • Russia
                        PFC does not work, in operating mode it should be about 400v.
                          • 12196
                          • U.S.
                          pfc driver bad maybe?
                          • R_J
                            • 9535
                            There is no PFC circuit on this board.
                            • R_J
                              • 9535
                              There are different 5 volt circuits, A5V and B5V. Is the A5V also fluctuating? Also check the 13v supply on DM852 cathode, is it changing?
                              • lotas
                                • Jan 2016
                                • 4601
                                • Russia
                                Here is a piece of the diagram
                                • sempre
                                  • Nov 2020
                                  • 21
                                  • Italia
                                  I checked rm802 (close to the transformer output) and it is open! Tomorrow I try to replace it, I have to look for it on some other board.
                                  Thanks everyone for helping me!
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    I see no PFC. If you are running 220vac. Voltage seems a little low. I think it should be around 310v
                                    • R_J
                                      • 9535
                                      That would do it.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        I think that resistor feeds the vcc to srtw6052
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
