Samsung T22b300 power supply problem
  • sempre
    • Nov 2020
    • 21
    • Italia
    Re: Samsung T22b300 power supply problem
    rm802 was the right solution! Thank you all!
    • nomoresonys
      • 12128
      • U.S.
      Thanks, but your the one who found the bad resistor so you get all the credit, well done, nice save.
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • cheeky2
        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
        by cheeky2
        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
        06-15-2025, 05:12 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
