Samsung LT24C300EW BN44-00505A (PD23A0Q) Won't Turn On (No Standby Light)
  • bl4ck
    • Mar 2022
    • 10
    • italy
    Hi there, after checking other topics without solution to my issue I decided to open this thread asking for your kind help.
    As I wrote in the title, my Samsung monitor silently stopped working by turning totally off while I was using it with my pc.
    Fortunately, even I'm still a newbie in electronics, time ago I purchased a multimeter and so I've dissembled the monitor and got out the PSU:
    http://puu.sh/INodf/f2fe430b5c.jpg
    What I have tested/checked so far:
    fuse is fine, with cable to main disconnected the LED's doesn't come on.
    no visible burnt or blown caps or other components (it seems just dirt on the center).
    The integrated STR W6053S does not seem to give a short circuit between pin 1 and pin 3.
    Diode bridge does not seem short.
    Only thing I've notice is that the top left capacitor 50V CM852 seems just a little bit popped out and as a newbie with a simple multimeter I can say if it's really broken or not. Another thing is that when I did the continuity test on the diodes, the 2 bigger on the right DM852 and DM853 (I've circled them on the attached image) seems to be in short circuit.
    What would you do? Do I have to change all these 3 parts (Capacitor and 2 diods) or maybe it's just the capacitor that make those diods short circuit? What test I still do? (always taking in mind that I'm still at the beginning in this field )
  • R_J
    • 9556
    Re: Samsung LT24C300EW BN44-00505A (PD23A0Q) Won't Turn On (No Standby Light)
    The capacitor is bad but won't shut down the power supply, you will need to remove the diode to check them properly but if they check shorted in circuit one is likely bad
    • bl4ck
      • Mar 2022
      • 10
      • italy
      yeah, I'll desolder them for sure.
      Today I tried to measure the voltage of 5v and 13v to the Mainboard but instead of null or a fixed value I get random numbers.. Is that mean there's also something else not working properly? or it's just the consequences of the bad capacitor?
      Btw someone has found the diagram of this PSU? cause can't find this exact model
      • dskall
        • Oct 2016
        • 2905
        • usa
        Did you check the diodes?
        • bl4ck
          • Mar 2022
          • 10
          • italy
          Yes, as i wrote in my first post, TWO of them resulted short circuit, I've circled them in the picture in that attachment.
          Now I wanted to order them, along the capacitor but it's not easy to read the type are they and I want to avoid ordering the wrong one..
          So has anyone the DIAGRAM of this exact board?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I’ve had shorted sb6100 and uf5402 diodes on this unit check for shorts.
            • R_J
              • 9556
              If you have not replace the bad parts yet, what do you expect?
              What are the numbers printed on the diodes?
              • bl4ck
                • Mar 2022
                • 10
                • italy
                You're right, but I did that voltage too just to make some other test before to order some component, wait days and later discover that I've to order and wait others days till they arrive.. anyway as I said i have some difficulty to read some type of components and can't find the exact schematic file, if anyone have it would be great
                • bl4ck
                  • Mar 2022
                  • 10
                  • italy
                  Originally posted by ReeceyBurger123
                  I've had shorted sb6100 and uf5402 diodes on this unit check for shorts.
                  Please l, as I can't find exactly those numbers, can you circle them on the picture posted on my first post? Thank you!
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 944
                    What we were asking you is to check the diodes out of circuit, just desolder one side and lift it - put your meter in diode mode and check if they block voltage one side and turn your probes around and check if they allow voltage the other side. Report back.
                    • bl4ck
                      • Mar 2022
                      • 10
                      • italy
                      Today I've finally got some time and I've done what you were asking me guys. So I've desoldered one side and I've found that one of those 2 was a short circuit. In meantime, I also received the replacement of them and a new capacitor. So I've replaced the single shorted diode and the capacitor. All gone fine apart ONE single issue: when I finished soldering the capacitor and I wanted to cut the exceeded length by mistake I took out of its place a side from the PCB as you can see from the attachment..
                      I think I've to build manually a link.. but where?
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Except for soldering I'm not sure anything is bad there.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          looks like part of the pcb trace has torn of the board thats around the capacitor leg.
                          • bl4ck
                            • Mar 2022
                            • 10
                            • italy
                            Here you can see it better (in attachment)
                            • R_J
                              • 9556
                              Just bend the capacitor lead towards the solder point (the arrow goes through it) and solder it there, if the lead is too short use a scrap of wire and wrap it around the cap lead and solder it then solder the other end to that pad. Or scrape a bit of the green paint from the trace next to the cap lead to expose some copper trace and the cap lead to it.
                              • bl4ck
                                • Mar 2022
                                • 10
                                • italy
                                Thank you very much for the detailed reply so I haven't to do many question, but excuse me just a little one, about the wire ☺️ It does makes difference if I use one previously cutted from a vcc/gnd of an old general usb cable or if I use a wire from an ac plug?
                                And one last thing, about where to solder, for me would much easier to link and solder it directly to the solder point (under my red arrow) instead of scraping the green paint, is this last way (scrap paint pad) better in terms of quality?
                                • R_J
                                  • 9556
                                  You need to connect the positive lead of the capacitor to the trace, how you do it is up to you, I gave you a couple options. I suggested using a piece of wire only if the positive lead from the capacitor would be too short to reach that solder pad.
                                    • 12206
                                    • U.S.
                                    one video there, many more if needed: https://www.youtube.com/watch?v=ztuosZQVDFU
                                    • bl4ck
                                      • Mar 2022
                                      • 10
                                      • italy
                                      In the end it was easier to do it than to say it, and it also came out just like the factory.. ok I'm not so sure about that last thing but it worked great giving me continuity from the capacitor pin to the entire pad with the tester.
                                      After that I quickly did the backlight test (by giving power and leaving the main board unlinked) that this time powered on, and secondly I checked the voltage which gave me a stable 5v and 12v.
                                      So when finally I plugged everything together, the monitor back to work!! http://puu.sh/IPgj5/ef3d89c9f3.jpg
                                      What can I say guys, thank you immensely for giving me support for the various steps! I leave attached how I solved this last hiccup but the main issue was "simply" the bad capacitor a little bit popped and one diode that was giving short circuit. So I hope it can be useful so I can reciprocate help someone else in my same situation 😊
                                      • ChristianBr01
                                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                        by ChristianBr01
                                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                        04-23-2025, 01:48 AM
                                      • Kaar3l
                                        Samsung QLED QE65Q7FNAT only standby light
                                        by Kaar3l
                                        TV: Samsung QLED QE65Q7FNAT
                                        PSU: BN4400940A
                                        MB: BN94-12832K
                                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                        09-24-2024, 01:35 PM
                                      • Nicktronic
                                        Samsung UN70NU6070F Standby Light flashes twice
                                        by Nicktronic
                                        Hey Everyone,
                                        So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                        I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                        03-27-2023, 07:01 PM
                                      • marcinq
                                        Samsung UE60KS7000 No Standby Light
                                        by marcinq
                                        I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                        I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                        05-26-2025, 11:36 AM
                                      • SJX1290
                                        No Standby Light on Samsung SAMSUNG UE65NU7022
                                        by SJX1290
                                        I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
                                        My main suspect is bad flash memory, ...
                                        Any suggestions or can someone please​ check dump file, in the attachment
                                        Thank you...
                                        09-07-2024, 01:35 AM
