Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
  • lotas
    • Jan 2016
    • 4625
    • Russia
    Re: Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
    Check the voltage between gnd and these points where the arrows are.
    • Storyteller12
      • Jun 2020
      • 624
      Originally posted by DutchDIY
      I am finding a bunch of smd's beeping on both ends (with one probe to GND). That must not be good?
      No not good, but making progress. Now their should be a small black diode near those capacitors that are short. Check those diodes for continuity to find the short
      • DutchDIY
        • Feb 2022
        • 51
        • Nederland
        Thanks for showing me! I very much appreciate it!
        I have measured and added the image.
        • DutchDIY
          • Feb 2022
          • 51
          • Nederland
          These all beep continueously, see image. Might have missed some though.. not sure what those diodes should look like on the board. Could you maybe point them out?
            • 12206
            • U.S.
            unhook the other cables from the mainboard (isolate it) and see if all those remain short, they probably will, the good news is there's probably lots of substitutes for the mainboard so it should not be hard to find a replacement if you have to.
            • 3DIL
              3D!L
              • Jun 2021
              • 42
              • BRASIL
              #26
              there are some TVs (Samsung) that drive the LEDs only with the power supply, if it is the case of yours you can disconnect the main card from the source and leave the LEDs when applying energy in the source; this must drive the LEDs alone, so that it is useful if you have a problem on the main board, by not using it the starias discarding by default .. ps: when the LEDs are activated in that way they generate 100% of the brightness, they do not blink just turn on like a common lamp
              • DutchDIY
                • Feb 2022
                • 51
                • Nederland
                #27
                Now that's music to my ears!
                Been trying to find the exact same board, but found it to be hard to find.
                Any place I can see which would work (plug & play preferably)?
                Thanks bro!
                • DutchDIY
                  • Feb 2022
                  • 51
                  • Nederland
                  #28
                  Yea, they do. So maybe my best option is to find the cheapest main board that works.
                    • 12206
                    • U.S.
                    #29
                    can you recheck and make sure that's the exact model number?
                    • DutchDIY
                      • Feb 2022
                      • 51
                      • Nederland
                      #30
                      The one in the title I mistyped, in the OP I spelled it correctly; UE65H6400AW, Samsung.
                      • DutchDIY
                        • Feb 2022
                        • 51
                        • Nederland
                        #31
                        Main board says; bn41-02156a.
                          • 12206
                          • U.S.
                          #32
                          are those the numbers on the white sticker?
                          • DutchDIY
                            • Feb 2022
                            • 51
                            • Nederland
                            #33
                            This is the sticker on the back of the tv;
                            • lotas
                              • Jan 2016
                              • 4625
                              • Russia
                              #34
                              Bn94-07341l
                              • DutchDIY
                                • Feb 2022
                                • 51
                                • Nederland
                                #35
                                Oh I was checking here, oopsie.
                                • Diah
                                  • Feb 2013
                                  • 6384
                                  Standby;
                                  Pin 1: 0V
                                  Pin 2: 0V
                                  Pin 3: 0V
                                  Pin 4: 0V
                                  Pin 5: 12.88V (expected 13V)
                                  Pin 6: 0V
                                  Pin 7: 12.88V (expected 13V)
                                  Pin 8: 0V
                                  Pin 9: 12.88V (expected 13V)
                                  Pin 10: 0V
                                  Pin 11: 12.88V (expected 13V)
                                  Pin 12: 0.188V (idk what to expect? Legend says PS_ON)
                                  Pin 13: 12.88V (expected 13V
                                  Pin 14: 0V
                                  Pin 15: 0V
                                  Pin 16: 0V
                                  Pin 17: 0V
                                  Pin 18: 0V
                                  Next I will post the voltage after pressing On button.
                                  About the above voltages, those drop every second to just over 9V (and pin 12 drops slightly as well), and it coincides with the ticking of what I believe are the mosfets.
                                  yours MB working.... this set the standby <8V and when it power on go high 13V. when you press power on TV you look like turn off and on again so its drop to >8 then up to >12.
                                  when you have >12V on the socket just keep yours eyes on the Audio optical port if it lit red or not.
                                    • 12206
                                    • U.S.
                                    #37
                                    he has many caps on mainboard reading short., doubt that they are all short but there appears to be something wrong.
                                    • DutchDIY
                                      • Feb 2022
                                      • 51
                                      • Nederland
                                      #38
                                      Does not lit red.
                                      But before when I pressed power button on tv, the standby LED would go off and on again but now, when I press the power button, the standby LED is not responding. The remote isn't working either. The standby LED just stays red all the time.
                                      • DutchDIY
                                        • Feb 2022
                                        • 51
                                        • Nederland
                                        #39
                                        Do you know which main boards are interchangeable with the one currently in the tv? Then I can buy the cheapest if I find one.
                                        • Diah
                                          • Feb 2013
                                          • 6384
                                          Does not lit red.
                                          i wrote on your early post.. yours MB working... now its shorted and it could be because you went to messure voltage on chips op on useres request. which was all fine.. so the short happen.
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • Nicktronic
                                            Samsung UN70NU6070F Standby Light flashes twice
                                            by Nicktronic
                                            Hey Everyone,
                                            So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                            I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                            03-27-2023, 07:01 PM
                                          • Jackching
                                            Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                            by Jackching
                                            I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                            04-15-2024, 05:14 PM
