Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
  • DutchDIY
    • Feb 2022
    • 51
    • Nederland
    Hey everyone!
    I have a Samsung UE65H6400AW tv here that won't turn on.
    What I have tested/checked so far;
    • no visible burnt or blown caps or other components
    • power board seems in working order, voltages are oke, fuse is fine, with cable to main disconnected the LED's come on and stay on
    • have done various variations of resets by holding down the power button
    Edit: remote is ruled out.
    I am hoping that some of you can tell me what to check/test next. I am no stranger to soldering, and am totally committed to learning.
    Thanks for reading!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
    Need to check your voltages to mainboard in standby, and after you press power button.
    • DutchDIY
      • Feb 2022
      • 51
      • Nederland
      According to the imprint on the power supply board, pins 5,7,9,11 & 13 should have 13V.
      Upon plugging in the power coard, I measure 12.88V on all of these pins, but they drop to just over 9V about every 2 seconds before going back to 12.88V.
      After pressing the power button, there is no change in this.
      • DutchDIY
        • Feb 2022
        • 51
        • Nederland
        Anything else I can check?
        Edit:
        Maybe some useful info, upon pressing the power button a faint click can be heard soon after, coming from the main board.
        • DutchDIY
          • Feb 2022
          • 51
          • Nederland
          Should I buy another main board?
            • 12323
            • U.S.
            good possibility its the mainboard, when you get backlight on with that cable removed it usually means the backlight circuit and powerboard are ok. can you post a good clear picture of the connector on powerboard with the legend of the expected voltages? or just report the voltages you have in standby(tv plugged in) and when you power on the tv, report both conditions, as in: pin number, expected voltage and your actual voltage, example pin 1 ps-on, off 0volts, on 3.5volts.
            • DutchDIY
              • Feb 2022
              • 51
              • Nederland
              Thanks, will see if I can get one!
              • DutchDIY
                • Feb 2022
                • 51
                • Nederland
                The legend says 13V for 6 of the 18 pins, and I measure 12.88V on all, with it every few seconds dropping to just over 9V. I will post a pic soon.
                  • 12323
                  • U.S.
                  to repeat: " just report the voltages you have in standby(tv plugged in) and when you power on the tv, report both conditions, as in: pin number, expected voltage and your actual voltage FOR ALL pins, example pin 1 ps-on, off 0volts, on 3.5volts." I would never on purpose ask you to do anything unnecessary.
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Can you post good pics of your mainboard
                    • DutchDIY
                      • Feb 2022
                      • 51
                      • Nederland
                      Here are some pictures, are they good?
                      • DutchDIY
                        • Feb 2022
                        • 51
                        • Nederland
                        Standby;
                        Pin 1: 0V
                        Pin 2: 0V
                        Pin 3: 0V
                        Pin 4: 0V
                        Pin 5: 12.88V (expected 13V)
                        Pin 6: 0V
                        Pin 7: 12.88V (expected 13V)
                        Pin 8: 0V
                        Pin 9: 12.88V (expected 13V)
                        Pin 10: 0V
                        Pin 11: 12.88V (expected 13V)
                        Pin 12: 0.188V (idk what to expect? Legend says PS_ON)
                        Pin 13: 12.88V (expected 13V
                        Pin 14: 0V
                        Pin 15: 0V
                        Pin 16: 0V
                        Pin 17: 0V
                        Pin 18: 0V
                        Next I will post the voltage after pressing On button.
                        About the above voltages, those drop every second to just over 9V (and pin 12 drops slightly as well), and it coincides with the ticking of what I believe are the mosfets.
                        • DutchDIY
                          • Feb 2022
                          • 51
                          • Nederland
                          The readings are the same after pressing the power button.. but I used to see the standby LED react to me pressing the power button, don't see that happen anymore..
                          • lotas
                            • Jan 2016
                            • 4908
                            • Russia
                            Check the voltages on the converters on the motherboard.
                            • DutchDIY
                              • Feb 2022
                              • 51
                              • Nederland
                              Will check that, thanks, which pins of those chips should I check?
                              • lotas
                                • Jan 2016
                                • 4908
                                • Russia
                                Usually the output voltage is on the inductor.
                                • DutchDIY
                                  • Feb 2022
                                  • 51
                                  • Nederland
                                  I'm sorry I don't know which of those feet to probe with the multimeter.
                                  I added a closeup of one of the 8 legged chips.
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    Start checking the smd capacitors and diodes on the main board. Where ever you see an 8 pin ic I would probe around there first. If I’m not mistaken I fixed this board before and it was a bad diode
                                    • DutchDIY
                                      • Feb 2022
                                      • 51
                                      • Nederland
                                      I am finding a bunch of smd's beeping on both ends (with one probe to GND). That must not be good?
                                      • lotas
                                        • Jan 2016
                                        • 4908
                                        • Russia
                                        See datasheet.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
