SAMSUNG UN70TU7000F no image
  • charlie555
    • Feb 2018
    • 76
    • usa
    This tv has no image, but does have sound and backlights, when I remove the cable between the ps and main board I have lights. And main board to the panel driver board It goes dim. I did notice the two other panel boards on the edges left and right if I remove the jumpers from the center board the backlights stay on if I connect the jumper the tv goes dim and flickers and 2 red blinks. Need help
    • 12276
    • U.S.
    Re: SAMSUNG UN70TU7000F no image
    may be a problem with the panel, maybe try the tape cutoff method: https://www.youtube.com/watch?v=pfrRhw7-ZII
    • dskall
      • Oct 2016
      • 2905
      • usa
      Need some good pictures of boards.
      • charlie555
        • Feb 2018
        • 76
        • usa
        I'm new to this can't find the edit and every time I try to load all the pic only one shows.
        • charlie555
          • Feb 2018
          • 76
          • usa
          Here are pics of the boards
          • alfatv
            • Sep 2020
            • 353
            Looks like panel issue, you can try scotch tape on the jumper cable between panel boards.
            • charlie555
              • Feb 2018
              • 76
              • usa
              Ok thank you nomoresonys sent a link will check it out. Thanks guys
              • nlocascio84
                • Mar 2022
                Did you ever figure out a solution? I have the same issue. Thanks
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Probably a short in one of the panel board caps.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • C152Heavy
                    by C152Heavy
                    Summary for TL-DR readers:
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
