Samsung panel help un65js8500 the other from un65ks9500
  • Storyteller12
    • Jun 2020
    • 625
    Can someone help me find out if these 2 Samsung panels are compatible?
    I tried to compare on panelook.com but they don't have them listed.
    1 is from a un65js8500 the other from un65ks9500
    Picture attached of the labels on both.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Samsung panel help
    The KS9500 seems to have the mainboard+tcon in just one board, and cables that run directly to the panel, the JS8500 has a separate t-con closer to the panel, even if the cables do fit, that does not guarantee that it will work.
    I would say, don't risk it unless you don't have to spend money on parts and have the two TVs side by side.
    • alfatv
      • Sep 2020
      • 353
      One is 3D, another is curved, very unlikely.
      • Storyteller12
        • Jun 2020
        • 625
        I have both tv's and parts in front of me. They have the same connections even though 1 has a tcon and the other does not. They are both 10 bit SVA panels and both are Samsung brand.
        Just not sure if the power and grounds are in the same location
        • Storyteller12
          • Jun 2020
          • 625
          The curved part shouldn't matter however the 3d part might. Not sure though
          • Diah
            • Feb 2013
            • 6604
            show us focused high resolution photos on both panels sockets the left and right
            • alfatv
              • Sep 2020
              • 353
              You can swap all boards and see if it works. For backlight you may need to use original power board.
              • Storyteller12
                • Jun 2020
                • 625
                I'll get them tomorrow for you
                • ducky29
                  • Dec 2015
                  • 369
                  • Europe
                  As far as I know the picture that you have posted is not the screen model. Its the model for the case+diffusers and stuff.
                  Check both left and right side of the screen and you should see a model number printed on 1 of the sides. Then compare both models.
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Hope the pics are clear enough. Took them with my phone real quick.
                    1st 3 pics are the JS panel and the last 2 are the KS panel
                    • Diah
                      • Feb 2013
                      • 6604
                      both same layout and VCC. should working with out any issue
                      • Storyteller12
                        • Jun 2020
                        • 625
                        Re: Samsung panel help un65js8500 the other from un65ks9500
                        Thanks Diah. I appreciate the help. I will let you know how it goes.
                        • handsworth
                          • Oct 2015
                          • 175
                          Since you have access to both screens, are they the same? Printed on the buffer boards is a part#.
                          • ducky29
                            • Dec 2015
                            • 369
                            • Europe
                            Check the model numbers on the green pcbs directly connected to the screen before you make any move!!!
                            • Storyteller12
                              • Jun 2020
                              • 625
                              I'm not in front of it at the moment but there not the exact same. That's why I asked if they were compatible.
                              Do you know anyway to confirm other than same pcb model #s?
                              • Diah
                                • Feb 2013
                                • 6604
                                MAN ...you did quoted wrong post.. LOL
                                to any other whom call them self professional tech where they just steal from here firmware and dumps and later he/she sell it on ebay or over here too for small potato 10$ .. go to aliexpress and buy with yours 10$ LVDS converter 55 /56 /51 /49 /41 pins then you will be able to run any panel as you wish if you do know how panel works. i do doubt you know.
                                OP. you are not mentioned over here... go head and show them photo of yours coming work.
                                • Storyteller12
                                  • Jun 2020
                                  • 625
                                  Sorry, I don't understand. Not sure exactly what you mean.
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    Update. It may work however I was going to put the js panel into the ks frame. Unfortunately the js panel has cof tabs on the side and will be seen if put into the Ks frame.
                                    So a no go for me.
                                    Thanks for all the input though
                                    • howardc64
                                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                      by howardc64
                                      • Prior owner tried a replacement main board. No difference.
                                      • Samsung 2x red blinking standby LED = panel fault
                                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                      07-19-2025, 10:54 PM
                                      09-07-2024, 05:50 AM
                                    • triplefour
                                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                      by triplefour
                                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                      tcon is built into mainboard.
                                      Only one cable goes to panel boards.
                                      there is a cable from one panel board to the other that links them.
                                      cost cutting measure that results in us having harder time to diagnose.
                                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                      07-28-2022, 07:59 PM
                                    • NWArkGuy
                                      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                      by NWArkGuy
                                      Well, I will be the first to admit that I screwed up...
                                      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                      I have 2 that I have found and have in my possession. ...
                                      10-12-2023, 10:13 PM
                                    • KYBOSH
                                      Samsung UN50TU8000 - Dead Panel Forensic Questions
                                      by KYBOSH
                                      I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                      When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                      When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                      Later I checked for shorts on the panel PCB boards but could not find anything.
                                      When I took a look with the FLIR i noticed the 2 resistors...
                                      08-10-2024, 08:39 AM
