LG 55LA970W - No sound or picture.
  • chopper00
    • Jan 2012
    • 60
    As above, turns on, speaker drops out of bottom of unit, no sound or picture. If I force power supply on all voltages correct and backlights come on ok. Any troubleshooting tips for boards? TIA
    • 12330
    • U.S.
    Re: LG 55LA970W - No sound or picture.
    That test usually means the powerboard and backlights are ok. Try shining a flashlight on the screen hit menu see if you see any text or image if not check the voltage on each side of tcon fuse, negative probe to chassis ground positive probe on each end.
      • 12330
      • U.S.
      Could try unhooking the bluetooth module and camera etc., you tried with both remote and tv buttons right? that's if this model has buttons.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Are you getting power to your t-con board?
        • chopper00
          • Jan 2012
          • 60
          No image with flashlight test, No difference with Bluetooth module and/or camera disconnected, Both buttons and remote do the same thing and no power to t-con board. I’m thinking mainboard issue ??
            • 12330
            • U.S.
            Did you check tcon fuse, you mean no power getting from mainboard to tcon?
            • chopper00
              • Jan 2012
              • 60
              Yes, no power to t-con and fuse is good
              • dskall
                • Oct 2016
                • 2905
                • usa
                I would say it is mainboard problem.
                • chopper00
                  • Jan 2012
                  • 60
                  Replacement mainboard ordered, will update once fitted.
                  • chopper00
                    • Jan 2012
                    • 60
                    Mainboard arrived and it’s a slightly different board. 55LA965W board. Tv powers on but no control so I know it’s a mainboard issue. Looking for a mainboard if anyone has one. EBT62700302
                    • stinger
                      Samsung UN70TU6980FXZA no sound no picture but does have backlights
                      by stinger
                      When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                      04-17-2024, 03:06 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
                    • EazyBone
                      Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
                      by EazyBone
                      Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
                      Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
                      Now what exactly do I need to do in order to attempt to fix this issue?
                      do I have to take each one...
                      12-24-2023, 06:59 PM
