DPS285BP 5v standby transformer blown
  • Hounddoghill
    • Feb 2022
    • 6
    • usa
    Sharp TV LC-80LE633U
    Power supply board DPS 285BP Run TKB096WJQZ
    Standby transformer markings (attached picture)
    MP-130I(01)
    AV-DP11153 Delta
    Dcum 1244(03) H6P
    So an event in the primary exploded the cap (C7901)on pin one of the Standby circuit IC. So after replacing a couple diodes a the 2.2ohm resistor(fuse) I found the transformer inputs are open.
    Anyone know about replacements for this transformer?
    I suspect the original is not available.
    https://www.badcaps.net/forum/images/smilies/silly.gif
  • R_J
    • 9535
    Re: DPS285BP 5v standby transformer blown
    Which pins are you checking on the transformer?
    • Hounddoghill
      • Feb 2022
      • 6
      • usa
      1-2 and 3-4 are both open
      5-7 Output still has .1 ohm (6 and 6 windings in parallel)
      there is a suggested transformer spec on the data sheet for standby power IC.
      1-2 is 72 windings
      2-4 is less don't recall
      Pretty sure it's dead
      • R_J
        • 9535
        That's not the configuration, the primary is 2~3, The vcc feedback is 1~4 Pins 5~7 are the secondary.
        Also check R7907, and I would also replace C7907 and C7918
        • Hounddoghill
          • Feb 2022
          • 6
          • usa
          good info
          2-3 is 2.8 ohm
          1-4 is open
          should 1-4 be open?
          • R_J
            • 9535
            No 1~4 should not be open. Check the transformer leg to see if the wire is broken, and also make sure you are making a good connection with your probes
            • Hounddoghill
              • Feb 2022
              • 6
              • usa
              Checked again and 1-4 open and bobbin wires look solid at pins.
              So I think I need a replacement plan.
              • Hounddoghill
                • Feb 2022
                • 6
                • usa
                I used my digital microscope and the coil at pin one is burnt.
                Second photo is good side.
                Anyone ever take one of these part and rewind?
                I am going to try and open.
                Or know of a a replacement
                • daltonjr.
                  • Jul 2016
                  • 45
                  • Austria
                  I have exact same transformer from Grundig Tv that is shorted. Have you fixed it, found replacement one or some alternative... ? Thanks!
                  • daltonjr.
                    • Jul 2016
                    • 45
                    • Austria
                    Does anyone know if the two pins on secondary are ment to be shorted / 0 resistance, or that indicates a faulty transformer?
                    • R_J
                      • 9535
                      You are measuring the DC resistance of the winding, basically a piece of wire, it will check shorted or less than 1Ω
                      • Clifton11283
                        • Aug 2022
                        • 10
                        • Malta
                        I have a similar issue on a DPS-162KP-1A power supply board on a sharp TV. I found fuse F7001, resistor R7900, capacitor C7901, IC7903 blown. Cannot find any further faulty components but when I test the TV with a serial bulb circuit to check for short circuits, the bulb is lighting which means I still have a short circuit somewhere. Any help what can I check further please?
                        • algutria
                          • Oct 2023
                          5-7 shall be about 16 ohms in a good transformer.
                          What I did is to buy a power cards for parts in e-bay for 25 dollars. that include the transformer.
                          Usually when transformer T7901 is shorted 0.0 to 0.2 between terminals 5-7 blows the cap C7817 (1nF) or the input resistor R7900 (2.2 Ohms)
                          • algutria
                            • Oct 2023
                            It is shorted. Shall be around 16 Ohms in a good transformer terminals 5-7
                            • R_J
                              • 9535
                              The secondary winding is small and the DC resistance of the wire will be close to 0Ω
                              • denisten
                                Sony STR-DB870QS standby transformer
                                by denisten
                                Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
                                04-14-2023, 03:24 AM
                              • nubie
                                Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
                                by nubie
                                Please help me ID the blown chip and point me where the short might be.
                                I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
                                The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
                                Anything I should check first for a short?
                                Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think...
                                01-05-2023, 06:06 PM
                              • notallbad
                                Sony Cmt-cp33md power transformer blown
                                by notallbad
                                Power transformer has open circuit on the 230v primary side, its tapped for 115v too which is also open so most likely the thermal fuse has blown. It doesnt look like it would be possible to open it up to check the thermal fuse so looking to replace.
                                What are peoples thoughts on repair?
                                replace the one transformer with 2
                                replace like for like, though unlikely to find a direct replacement...
                                01-22-2023, 03:47 PM
                              • tvguy12012012120
                                by tvguy12012012120
                                02-07-2025, 05:13 PM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
