Sharp LC-40FG2241KF dead
  • Judderman69
    • Jan 2022
    • 4
    • United Kingdom
    Hello and greetings from the United Kingdom, I'm looking for some help in repairing my grand daughters 'dead' Sharp LC-40FG2241KF smart tv. I have replaced the following damaged parts on the main PCB (TP.MS6486.PB711) :- fuse FB1, switch mode chip UB101, MOSFET QB101,capacitor CB116, resistor RB106, RB148 and a track from UB101 pin 6 to QB102.
    Unfortunately resistors RB105 and RB108 are also open circuit and because of their size (0201) I don't know their value. Could some kind soul please tell me or point me toward a schematic with a parts list, a very big ask but for this I would very very grateful and be forever in your debt!
    Thanks in anticipation
  • yokoono
    • Apr 2010
    • 481
    Re: Sharp LC-40FG2241KF dead
    https://www.electronica-pt.com/esque...p9495dj-71790/
    • Judderman69
      • Jan 2022
      • 4
      • United Kingdom
      Thanks yokoono for your speedy reply but no cigar this time. The circuit described in your link is way off, I think there are many revisions and variations of this PCB. There are several white labels attached to the board and this is the one that makes most sense.
      Model:-40FG5241KF
      TV:- 20180510-093411
      P/O:- PO41Z-2-CVTE
      The smp chip is an LD7537R and the resistors supply a type 2A transistor emitter follower used I guess to make MOSFET switch promptly.
      Sorry my bad, all the above components are on the primary of the switching transformer.
      • R_J
        • 9535
        All I found so far is this, It uses the same LD7537 ic so maybe it will help.
        • lotas
          • Jan 2016
          • 4579
          • Russia
          There is a diagram, but without the ratings of the components.
          • MarkC1970
            • Feb 2022
            • 22
            • Wales
            Hi Judderman69, did you ever find a link to the correct MS6486.PB711 schematic? I have one with a failed boost converter for the LED's that is causing me a headache. Thanks.
            • Judderman69
              • Jan 2022
              • 4
              • United Kingdom
              Hi MarkC1970,
              I haven't found a schematic with a component list, and probably never will as this depth of info may break manufacturer non disclosure. At the moment I'm awaiting more components from China. I've also seen the complete board for sale from https://www.tvparts.co.uk/index.php?...lc-40fg2241%20 I may buy it just to get the info, good luck repairing yours. Cheers
              • MarkC1970
                • Feb 2022
                • 22
                • Wales
                Originally posted by Judderman69
                Hi MarkC1970,
                To solve my problem I have purchased a different board for £8 with the same boost coil just to pinch it. The PSU is working fine on my board and if you post pics of the components you need I will happily tell you what value they are.
                • MarkC1970
                  • Feb 2022
                  • 22
                  • Wales
                  Sorry, I just scrolled up and saw you want 105 and 108. I will check them later.
                  • johnny20082008
                    • May 2010
                    • 8
                    hi,
                    soft usb or nand backup
                    SHARP LC-40FG2241KF
                    LY.22P10G001
                    TP.MS6486.PB711
                    ​pls
                    • borstar_micke
                      Dead Sharp Aquos LC-32LE430E
                      by borstar_micke
                      My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
                      I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
                      Not a master with the multimeter, which is cheap and 10-15year old btw...
                      So please make it basic...
                      To the issue at hand.
                      As stated, the tv is totally dead with no standby light....
                      03-23-2023, 09:14 AM
                    • metropical
                      Sharp lc32d42u seems dead
                      by metropical
                      plugged in after being off for quite some time. No OPC lights. Tried flashlight test for backlight check, nada.
                      Pulled the PS and checked all diodes including the 5w(?) D7908 that was the issue last time. All diodes check OK in circuit with DVM diode test.
                      No caps look unhappy. It is 17 years old. Was gonna fix and give to my brother.
                      But is there anything else to try or is it likely met its match.?...
                      09-28-2024, 05:41 PM
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
                    • disorder
                      ps5 edm-033 dead after hdmi/usb ports destroyed
                      by disorder
                      hello guys,
                      i need help to repair a edm-033 ps2
                      history : as always hdmi port and usb ports destroyed after unplugged
                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                      so i changed it
                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                      i don't see any projection of liquid metal on pcb.
                      01-14-2025, 12:48 PM
                    • Joekhoe
                      Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                      by Joekhoe
                      Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                      I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                      The replacement as follows:
                      1. IC7905 : TNY264PN (first found exploded)
                      2. Q7915 : BT169D (exploded too)
                      3. IC7901 : 1608B (controller ic)
                      4. IC7601 :...
                      09-17-2020, 05:52 AM
