Philips LCD 42PFL5432D/37 - Bad PSU
  • nuklear
    • Feb 2011
    • 15
    Re: Philips LCD 42PFL5432D/37 - Bad PSU
    I had the same issue on my Philips I replaced the bad caps but I still have the chirping noise and no standby light at all. I zeroed the noise down to an area but dont know how to go about repairing/testing it. It seems like it is coming from the yello block left of D (picture from first post) or the small reddish/brown thing just above D. Any help/insite on this would help.
    • nuklear
      • Feb 2011
      • 15
      It seems to be coming from the transformer next to D. Is there any way to replace that? Would that cause a chirping noise when plugged in? What do the numbers at the top of the transformer mean? 80tl37t912 ls
      pph6012al
      lse-b9 0747f2
        master hoarder
        • May 2008
        • 12175
        Do you have a multimeter?
        If so, use it to check if there is a stand-by voltage present. Using the picture from the first post in this thread, the stand-by voltage will most likely be present somehwere on that connector where the arrow for "D" is. Most of the time, the stand-by voltage is usually 5v or so.
        If there is no stand-by voltage, replace the small green capacitor to the left of the transformer (if you haven't already done so). Also, what brand and series of capacitors did you use for your replacements?
        A picture of your power supply would also be helpful.
        • nuklear
          • Feb 2011
          • 15
          Well I had it check I was told it was the Transformer and I need a new psu. Before I buy a new psu, what are the chances it wrecked another board in this tv?
          • dougsoxman
            • Feb 2011
            I just recently bought one of these tv's with what i believe to be the same problem. The larger caps look slightly bloated on the top. I also have the chirping noise and wasn't sure if that was related to the caps, or if the transformer is bad like someone else suggested. Did the original poster ever get his to work? Was it just the capacitors that you replaced? Thanks
              master hoarder
              • May 2008
              • 12175
              #26
              Except in the backlight inverters, transformers very, very rarely go bad. With that said, there's a very big chance this power supply is repairable, and most of the time it's usually something simple too.
              The chirping could be caused by a couple of reasons:
              1) PSU tries to start but fails due to dry start-up capacitor (somewhat common failure and very easy to fix)
              2) PSU tries to start but fails due to bad output capacitors (slightly more rare... however, this issue should have been eliminated if you replaced that cap on the bottom next to the connector with a proper low ESR one)
              3) shorted output (not very common, but still easy to fix)
              If you had it checked at a TV repair shop, don't blindly believe in what they say. Most of them just swap the bad board with a new one and don't really analyze what have caused the failure in the first place. Moreover, the replacement board may have the same failure-prone capacitors, so you may end up with the same problems again down the road. Fixing your own power supply with proper, high-quality components is a much better way to go about this, and it's usually cheaper too.
              Very small, but they do exist.
              Nonetheless, I still think you should fix the old power supply (again, see above reasons). Start by posting pictures of your power supply. Get a multimeter too.
              Bloated capacitors are always a bad thing. Get them replaced first, then if needed, troubleshoot the power supply if it's still chirping.
              My recommendation is the same as above - start by posting large, clear pictures of your power supply as well as the brand and series that is printed on each capacitor (if you're not sure how to obtain this information, just post all of the info you see on each capacitor). This will help in determining proper capacitor replacements.
              • nuklear
                • Feb 2011
                • 15
                #27
                thanks for the reply. He said the magnet around the transformer was broke and thats what was wrong with it. he should me it was by taking the tape off and a piece fell off it. I am assuming this was the problem, i didnt buy a new power supply yet I just wish there was a way to fix the transformer instead of spending $300 on a new psu I can get a multimeter but I didnt know what points to test and what not.
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  I highly doubt that's the problem. This guy sounds like he doesn't know what he is doing (if he did, and if the transformer really was "broken", then he should be able to replace it and not tell you to get a $300 power supply). No offence, but the guy is probably just a typical board swapper.
                  Like I said, post some pictures of your board here and we can tell you what to measure with your multimeter and you how to troubleshoot it.
                  • nuklear
                    • Feb 2011
                    • 15
                    #29
                    no offense taken, he doesnt do this for a living but he told me he new the basics about fixing electronics. He had me call the company for a new transformer and they said it cant be bought. He showed me how brittle the "magnet" is around the transformer by pushing the edge and it broke again. can I get a new magnet? I took pics of the board w/o the transformer I will post them when I edit the size of them. And again thanks for the info and help!
                    • PlainBill
                      • Feb 2009
                      • 7034
                      With all due respect, I find this unlikely. A transformer usually consists of three parts - a core - in this case, ferrite; a plastic bobbin, and the windings. There is no 'magnet'. Ferrite is brittle, but usually the core of a transformer is quite hard - think of a clay pot. Pictures would go a long way toward convincing me that the part he broke off was of the core. To me, it seems far more likely it was the bobbin.
                      PlainBill
                      • nuklear
                        • Feb 2011
                        • 15
                        #31
                        Sorry I think what I called a magnet is the ferrite,lol. I dont know much about electronics. I dont think my friend means anyharm or trying to rip me off (didnt charge me anything) but I dont think he understands this much into it. Well here are the pics.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          I stand corrected. That certainly looks like the ferrite core is broken. The power supply is available for $75 online.
                          PlainBill
                          • nuklear
                            • Feb 2011
                            • 15
                            #33
                            could you post a link or send it to me? I looked and only found one for around 240.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I'm having problems finding it again. I found it by Googling either the part number or the TVs it's used in - it's also used in the 42MF437B. Alternate part numbers are 996500044559, ADPF24300R1P and 715T2432.
                              PlainBill
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2642
                                http://www.shopjimmy.com/philips-996500044559.htm
                                out of stock though
                                found this..
                                http://cgi.ebay.com/250742845392
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  For the 10 inline pics hosted offsite, please read the following
                                  https://www.badcaps.net/forum/showpo...5&postcount=12
                                  for future posts.
                                  --- begin sig file ---
                                  --- end sig file ---
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #37
                                    I stand corrected.
                                    As do I. My appologies for wrongly accusing your friend.
                                    Yep, looks like it's time for a new power supply.
                                    ...Or is it?
                                    I've always been a bit optimistic about fixing things, even if they have to be cobbled and kludged together in an ugly way sometimes.
                                    Looking at this power supply, I'm pretty sure we can either wire it to an external power supply or reuse a transformer from another power supply to make it work again.
                                    If you want to try any of that, post an overhead picture of the back (solder side) of the power supply so that I can see what kind of transformer and/or voltages this thing might need and how they can be wired.
                                    • nuklear
                                      • Feb 2011
                                      • 15
                                      #38
                                      Sorry about the pics, Thanks for the links! I am willing to try anything so here is more pics (hopefully done right this time). I want to fix this for my son as a "gaming tv" so it doesnt have to look too pretty but safe I also have the service manual if that would help.
                                      Last edited by nuklear; 02-20-2011, 07:10 AM. Reason: I think the manual might help.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #39
                                        Yeah, it looks like it should be do-able, since there's only a single output for the standby power.
                                        Does the service manual have a schematic of the power supply? If so, this would be very helpful. We need to determine what output voltage is needed for the standby power. If you know how to read schematics, look up the voltages on the connector next to that 16v, 2200uF Rubycon PX capacitor.
                                        Otherwise you can also post the service manual here or just take a screenshot (with Print Screen key) of the power supply schematic and upload that.
                                        Lastly, can you tell me the part number of IC907? Thanks.
                                        *EDIT*
                                        Actually, just post a screenshot of the schematic if possible. I just saw something that needs to looked at in more detail.
                                        • nuklear
                                          • Feb 2011
                                          • 15
                                          #40
                                          I hope I did that right lol. and this is what i seen in the "spare parts list" IC907 9965 000 43345 TEA1507P/N1. Again thanks for helping!
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            Yesterday, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • Cornito
                                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                                            by Cornito
                                            Hello Team,
                                            New issue on LCD panel where I need to find out the cause and the potential solution.
                                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                                            VHG VGL CKV... are the sames on...
                                            03-08-2024, 06:41 AM
