TOSHIBA 37CV505D TV turns on and then off
  • Ukdigger
    • May 2020
    • 121
    • England
    #41
    Re: TOSHIBA 37CV505D TV turns on and then off
    I've got 24v on power board connector P860, The flash I can see is the blue LED on the inverter board on off for 1 second
    • Ukdigger
      • May 2020
      • 121
      • England
      #42
      all five fuses on power board are good
      • R_J
        • 9628
        I suspect you have either a bad connection to the ccfl's in the panel or a bad cclf.
        • Ukdigger
          • May 2020
          • 121
          • England
          #44
          could I connect a scrap 19 samsung tv screen to the inverter to test if its the cclf's?
          • Ukdigger
            • May 2020
            • 121
            • England
            #45
            Samsung 932MW
            • R_J
              • 9628
              It may not work as there would be too high a voltage going to the Samsung ccfl, as it likely only has two single (around 15") ccfl tubes in its panel. I don't thing it would damage the inverter but you never know.
              • Ukdigger
                • May 2020
                • 121
                • England
                #47
                I've got a 42 Bush lcd as well
                  • 12323
                  • U.S.
                  #48
                  Backlight tester on amazon, 20 bucks for most of them, very handy tool, strike that, the one I was looking at is only for led backlights.
                  • Ukdigger
                    • May 2020
                    • 121
                    • England
                    #49
                    I've got an led tester but I thought it wouldn't work on ccfl's
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #50
                      https://www.ebay.co.uk/itm/281737745...IAAOSwhU1fcUmC
                      https://www.youtube.com/watch?v=5ndNfga8eTk
                      have you stripped the lcd panel down yet you may find a bad connection
                      • Ukdigger
                        • May 2020
                        • 121
                        • England
                        #51
                        no not yet
                          • 12323
                          • U.S.
                          #52
                          10 bucks: https://www.amazon.co.uk/TuToy-Inver...s%2C169&sr=8-6
                          • Ukdigger
                            • May 2020
                            • 121
                            • England
                            #53
                            I was trying to eliminate the inverter being the problem first
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #54
                              no not yet
                              maybe this should be your next step then as you would need to strip it down too test the ccfls anyway.
                              If you have never stripped down a lcd panel watch a few youtube guides first as the lcd panel is very thin and easily damaged plus you need too keep all the diffuser sheets in the correct order etc.
                              • Ukdigger
                                • May 2020
                                • 121
                                • England
                                #55
                                I did one about a year ago
                                  • 12323
                                  • U.S.
                                  #56
                                  My thought is it's a good investment, there should be a lot of ccfl tv's becoming available as they age, they might not have the very best picture but they are SO much more reliable than led lit tvs.
                                    • 12323
                                    • U.S.
                                    #57
                                    Have 3 circa 2006, 2007 and 2009, going strong.
                                    • Ukdigger
                                      • May 2020
                                      • 121
                                      • England
                                      #58
                                      it's not the money it will take 1-2 months to come from china
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        If you have the time and the space maybe strip the set down you can visually inspect the ccfls and the connection points hopefully its a easy fix. China on average at the moment is taking 25 days but there holiday season now i think.
                                          • 12323
                                          • U.S.
                                          #60
                                          Bummer, here amazon sends them out in 2 days.
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            09-06-2024, 05:33 AM
