TOSHIBA 37CV505D TV turns on and then off
  • Ukdigger
    • May 2020
    • 121
    • England
    #41
    Re: TOSHIBA 37CV505D TV turns on and then off
    I've got 24v on power board connector P860, The flash I can see is the blue LED on the inverter board on off for 1 second
    • Ukdigger
      • May 2020
      • 121
      • England
      #42
      all five fuses on power board are good
      • R_J
        • Jun 2012
        • 9627
        I suspect you have either a bad connection to the ccfl's in the panel or a bad cclf.
        • Ukdigger
          • May 2020
          • 121
          • England
          #44
          could I connect a scrap 19 samsung tv screen to the inverter to test if its the cclf's?
          • Ukdigger
            • May 2020
            • 121
            • England
            #45
            Samsung 932MW
            • R_J
              • Jun 2012
              • 9627
              It may not work as there would be too high a voltage going to the Samsung ccfl, as it likely only has two single (around 15") ccfl tubes in its panel. I don't thing it would damage the inverter but you never know.
              • Ukdigger
                • May 2020
                • 121
                • England
                #47
                I've got a 42 Bush lcd as well
                • nomoresonys
                  • 12322
                  • U.S.
                  #48
                  Backlight tester on amazon, 20 bucks for most of them, very handy tool, strike that, the one I was looking at is only for led backlights.
                  • Ukdigger
                    • May 2020
                    • 121
                    • England
                    #49
                    I've got an led tester but I thought it wouldn't work on ccfl's
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #50
                      https://www.ebay.co.uk/itm/281737745...IAAOSwhU1fcUmC
                      https://www.youtube.com/watch?v=5ndNfga8eTk
                      have you stripped the lcd panel down yet you may find a bad connection
                      • Ukdigger
                        • May 2020
                        • 121
                        • England
                        #51
                        no not yet
                        • nomoresonys
                          • 12322
                          • U.S.
                          #52
                          10 bucks: https://www.amazon.co.uk/TuToy-Inver...s%2C169&sr=8-6
                          • Ukdigger
                            • May 2020
                            • 121
                            • England
                            #53
                            I was trying to eliminate the inverter being the problem first
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              no not yet
                              maybe this should be your next step then as you would need to strip it down too test the ccfls anyway.
                              If you have never stripped down a lcd panel watch a few youtube guides first as the lcd panel is very thin and easily damaged plus you need too keep all the diffuser sheets in the correct order etc.
                              • Ukdigger
                                • May 2020
                                • 121
                                • England
                                #55
                                I did one about a year ago
                                • nomoresonys
                                  • 12322
                                  • U.S.
                                  #56
                                  My thought is it's a good investment, there should be a lot of ccfl tv's becoming available as they age, they might not have the very best picture but they are SO much more reliable than led lit tvs.
                                  • nomoresonys
                                    • 12322
                                    • U.S.
                                    #57
                                    Have 3 circa 2006, 2007 and 2009, going strong.
                                    • Ukdigger
                                      • May 2020
                                      • 121
                                      • England
                                      #58
                                      it's not the money it will take 1-2 months to come from china
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #59
                                        If you have the time and the space maybe strip the set down you can visually inspect the ccfls and the connection points hopefully its a easy fix. China on average at the moment is taking 25 days but there holiday season now i think.
                                        • nomoresonys
                                          • 12322
                                          • U.S.
                                          #60
                                          Bummer, here amazon sends them out in 2 days.
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
