sharp LC70EQ10U 2 slow, 2 fast blinks
  • Diah
    • Feb 2013
    • 6613
    Re: sharp LC70EQ10U 2 slow, 2 fast blinks
    good work.. open the menu setting and under picture setting show here the backlight setting of your tv
    BTW: as your tv work now.. with yours DMM put the probe - &+ on each group Led- & and Led+ write down the value.. look to me the black color group some how different
    • JayPoorJay
      • Jan 2022
      • 149
      Yes. With tv on and image displayed
      Red = 232-238v
      Blue = 224 - 226,7v
      Black = 216 - 218v
      The backlight setting pic below. The TV is turned around and hard to get a good picture of...
      Including a picture of the second plug (there are only 2) off the power board. Other plug is for the LEDs...
      • Diah
        • Feb 2013
        • 6613
        Originally posted by JayPoorJay
        Red = 232-238v
        Blue = 224 - 226,7v
        Black = 216 - 218v
        ohhh my nick hurt by your photo,,, lol
        the setting okay..
        but this above value reading are you sure.. you put DMM black probe on each group LED- and the Red probe on each group Led+ ???
        • JayPoorJay
          • Jan 2022
          • 149
          No... But will do it now.
          I placed the black lead/probe on the CHASSIS of the TV...
          New values. The grounds are WHITE (see photo) above so black probe to white... Then:
          Red = 212v
          Blue = 203
          Black = 196
          Is it possible that the LED strips are different lengths and have differ #s of LEDs on each?
          • Diah
            • Feb 2013
            • 6613
            post clear photo of LED driver boards to see how many caps and circuit diagram
            • JayPoorJay
              • Jan 2022
              • 149
              Let me know if these are ok...!
              Note: this is the old power board. I replaced it. I cannot get a clear shot of the new one on the tv now because,,, well - see photo.
              Then, the main board...? Still not sure of the boards.
              ALSO, and important. Voltages fluctuate depending on what's on the screen. Just took some new readings while something else was "playing" on the set and the numbers were going up and down. BUT, the differences in the numbers were/are about the same.
              • Diah
                • Feb 2013
                • 6613
                hold on never messure again any pin of LED socket... wait for me
                EDIT: strips all same amount.
                group 1 pin red 1 & 3 ----- they have fault
                group 2 pin blue 5 & 7 ----- they have fault
                group 3 pin black 9 & 11 ----- are fine
                the issue happened as following;
                when you power on the TV and at time the logo SHARP displayed the Backlight turn on high round 80% or more the 2 fault strips pull high currents then MB turn all BL off.
                there are way to adjust the start logo BL brightness at service menu.. but with my poor English i will not involve in service menu with you. as its very risk section. hope some one native English speaker could help you ... or walk on the nightmare way -- buy 3 strips and take screen apart.
                • JayPoorJay
                  • Jan 2022
                  • 149
                  Ok. I'll Google how to adjust the power at start up... Are you saying that that is the ONLY thing shutting this tv down?
                  How can we get more people on this thread? Members who have a bit more English?
                  • Diah
                    • Feb 2013
                    • 6613
                    puling high currents at start up are knowing issues early time now days being changed,
                    from the photo i see the tv with out back cover.. if this case its stay always so.. there are small old trick to let the set didn't go to shutdown BL at start up.i used it even with modern LED TV if wont go to boot some time.
                    use any table lamp which it work with normal filament bulb. . the table lamp should be on and it wire we connect in series circuit with (LED-) which it pull high current in yours case the while cable of pin 3 or 7 or 11. start with cable pin 3 cut it and connect the table lamp wire in series circuit with it.. old trick from CRT time but remain effective.
                    • JayPoorJay
                      • Jan 2022
                      • 149
                      I don't feel experienced enough for that...
                      I know you said not to. But I just restarted the tv 3x and took readings each time a the 3 plugs. At start up they ALL went to about 240v and then, once the image came up on the screen, they settled to about 160v... The TV is on and playing at this point.
                      I'm not sure (at all) what to do now.
                      • Diah
                        • Feb 2013
                        • 6613
                        you had just now approved the subject i am talking on with yours measurements ( pulling high currents at start up )
                        table lamp method are yours answer for more 2 years or more working until you find other one to save the global from trash
                        • JayPoorJay
                          • Jan 2022
                          • 149
                          What can cause or does cause voltage spikes in the BLights?
                          • joblo37pam
                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                            by joblo37pam
                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                            10-26-2023, 02:17 PM
                          • Caimano
                            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                            by Caimano
                            MB G7AD-2G DAG7ADMB8D0 REV D
                            Processor i5 8265U
                            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                            02-06-2024, 10:14 AM
                          • klassic
                            Sharp Aquos LC-60LE635E three blinks
                            by klassic
                            Hi community,
                            I will describe my problem with a TV in those short following terms to be the most precise :
                            What i have :
                            power board DPS-162KP-1
                            main logic board QPWBXF733WJN2
                            symptoms :
                            white led light logo at startup,
                            after 2 minutes, blinking 3 times a row, repeating
                            no backlight (and apparently no picture, checked panel with flashlight)
                            no startup sound
                            powerboard investigations :
                            1-2 PNL : 0v
                            3-4 GND
                            5-6-7-8 UR : 13.15v
                            9-10-11-12...
                            10-24-2023, 01:39 PM
                          • Biruslapio
                            Panasonic P58V11B 8 and 12 blinks error "fix"
                            by Biruslapio
                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                            04-13-2021, 07:13 AM
                          • Anzio
                            Sharp LC60E79u 2 blinks power/3 Blinks OPC
                            by Anzio
                            I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                            The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
                            I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                            07-03-2020, 01:12 PM
