Sony xbr65x900c sound yes, no backlight or image.
  • nomoresonys
    • 12276
    • U.S.
    #61
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Hello, I checked F6101, is that the one you mean? https://www.shopjimmy.com/sony-1-474...-supply-board/
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #62
      f120 right hand side lower edge of board
      • nomoresonys
        • 12276
        • U.S.
        #63
        Oh ok thanks, I'll check it.
        • nomoresonys
          • 12276
          • U.S.
          #64
          Tests ok, tricky little fuse, I didn't even notice it.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #65
            as its on the secondary side it was worth checking as your missing voltages
            • Diah
              • Feb 2013
              • 6437
              how about T601 & T602 both they have 2 legs at primary side did you have any voltage on them or not? be careful this hot area the chassis should be main cap -
              • nomoresonys
                • 12276
                • U.S.
                #67
                Have .75 v, on all 4 legs of t601 and 2, - leg main cap as ground.
                • nomoresonys
                  • 12276
                  • U.S.
                  #68
                  that's with stby powr-on and bl-on jumped.
                  • Diah
                    • Feb 2013
                    • 6437
                    sure
                    • nomoresonys
                      • 12276
                      • U.S.
                      #70
                      Lol, I meant, I measured it with those 3 jumped.
                      • Diah
                        • Feb 2013
                        • 6437
                        of course.. the jumpers never move them until you have V on secondary
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #72
                          what printed on ic901?
                          • nomoresonys
                            • 12276
                            • U.S.
                            #73
                            a6069h, I think this is the equivalent: https://datasheetspdf.com/datasheet/STR-A6069H.html
                            • nomoresonys
                              • 12276
                              • U.S.
                              #74
                              Do you think I could test these particular edgelit tiny backlights with something like this?: https://www.youtube.com/watch?v=1qi9QS3tRfM
                              • Diah
                                • Feb 2013
                                • 6437
                                you have the screen out.. so show me the strip LED.. edge LED built in zener.. some time it lit but the zener open.. or it short didn't let LED to lit
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #76
                                  pics.
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #77
                                    There are tiny little + and - under the colored tape I guess that is, maybe I can test them with the dmm if I pull off the tape.
                                    • Diah
                                      • Feb 2013
                                      • 6437
                                      not with dmm, only led tester or any other v source because they are group could have 6-8 led in each.. each socket all group share the same + the dark wire you can feed each socket from the other end of the cable. so no need to pull off the tape
                                      if you are going to use DMM must be direct on each led on the strip
                                      • nomoresonys
                                        • 12276
                                        • U.S.
                                        #79
                                        Can't see where to put the leads, guess I'll get a tester, I think theyr'e on sale, had one but lost it somehow.
                                        • nomoresonys
                                          • 12276
                                          • U.S.
                                          #80
                                          I have to ask a nooby questions, I think I knew but certainly forgot the answer to, trying to diagnose this powerboard from input of ac all the way out the other side, a-z,
                                          1=I have expected voltage on stby and acdet pins, does that mean the bridge rectifier is ok, if not what voltages should I expect on the bridge rectifier, forgot exactly how to test it too, thanks.
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • Kartowl
                                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                                            by Kartowl
                                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                            04-23-2024, 12:57 AM
