Backlight to repair LED panels
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi everybody. I am looking for ideas on how to go about designing and building a box wherein there will be a relatively uniform light shining out of it and onto some kind of surface whether it be a diffuser sheet i don't know. I need to start repairing panel faults where you bridge missing voltages on the side COF IC's. So you need to see what you are doing ,the panel would be placed on this lighting box upside down so that you can get to the side cof ic testing points but still need to see what you are doing hence the backlight.
    Any ideas?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Backlight to repair LED panels
    So a box with a clear plastic sheet on the top with LEDs underneath.
    Broken tv parts or make one using a cut up roll of LEDs and a power supply.
    A piece of paper on the reverse of the plastic will diffuse the light.
    • angelos
      • Dec 2012
      • 571
      • South Africa
      Or maybe a tv whose led panel is cracked, we remove the panel and reassemble the set.
      Use the tv to diffuse the light that way?
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
