I have a lg tv here that is one of those commercial tv units. It will power on make a staticky sound then shut off. It does display a picture then it just shuts off what can I do? The psu has good standby voltage as well. I'm wondering if the lamp is dead possibly?
LG 37LC50C Turns on then off
Re: LG 37LC50C Turns on then off
I think the motherboard has a issue because when I was probing the psu connector accidentally shorted ps_on with 5v standby and it kicked on no issue. I imagine some bga/capacitor issue on mainboard. I'm buying a new motherboard and will report back.Last edited by Super360; 12-28-2021, 03:09 AM. -
Did the backlight work with the ps-on test?
Report the voltages on the inverter cable, 24V and bri, dim and the other two.Comment
18V=18V WHEN POWER IS PRESSED ON. 7v when power is off
18v=18V WHEN POWER IS PRESSED ON. 7v when power is off
6v= 6when power is on 0.700v when power is off
3.4v= 3.5v when power is on 0.700v when power is off
12v= 1.300v when power is off 12 volts when power is onComment
The voltages are fine except for the 5V pin. You must have noticed that too, Now I do not know if it's actually used by the TV, since there's 6V going to the mainboard, trace to find its source on the PSU board.
If the backlight stays on during the ps-on test it's not the inverter, the signals (bri, i-c, dim) that the mainboard is sending are normal.Comment
service manual if neededAttached FilesComment
I bought a repair kit for this psu. https://www.ebay.com/itm/tkit28-LG-3...-127635-2958-0Comment
i think these repair kits only have 6 capacitors in them fixesI bought a repair kit for this psu. https://www.ebay.com/itm/tkit28-LG-3...-127635-2958-0
SLOW START UP
STUCK IN STAND BY
C204
C205
C221
C222
C223
C232Last edited by vinceroger69; 01-01-2022, 08:41 AM.Comment
How i usually find whats in the repair kits and location of parts is too look on ohm supplies web site, kit kit103 is for your psu (good company i have used them a lot here in the uk)Comment
LOL I was like how did this mf find all these capacitor values. I was searching through the listing trying to find what you saw lol thank you man. Will give ya guys a update when these low-esr ebay special arrive.Last edited by Super360; 01-01-2022, 01:06 PM.Comment
does the backlight flash on and off i wonder if this is a 2 second too black fault as ccfl set
ignore the above, i see you can trick the backlight to stay on so not that.Last edited by vinceroger69; 01-17-2022, 04:09 AM.Comment
One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.Comment
This specification for the Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPANISH MEXICO HDWR COMMERCIAL PLAT boardview and SPANISH MEXICO HDWR COMMERCIAL PLAT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-07-2024, 12:40 AM
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
- Loading...
