lg 47LB585V help to identify ic please
  • jimbofz
    • Apr 2013
    • 539
    Re: lg 47LB585V help to identify ic please
    ok thanks will do .i will post results
    • jimbofz
      • Apr 2013
      • 539
      Well tiny tps54319 ic arrived
      removed s/c one
      checked all pins for s/c on board, prepared board
      fitted replacement , checked resistances
      i/p pins 1 and 2 had 5k to deck which was caused by zd2403 on 3.3v i/p
      powered up ,standby led ok 3.5v ok
      powered on no o/p from i/c no 1.5v on pins 10,11,12, no backlight
      no short on o/p
      so i suspect enable pin 15 not turning on
      this is proving to be a headache
      not giving up yet though
      trying to work out the start up sequence
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The data sheet says "pull below 1.2V to disable" so I gues a voltage greater than 1.2V will enable it.
        • lotas
          • Jan 2016
          • 4968
          • Russia
          The microcircuit may not fit well on the seat, it will not contact.
          • jimbofz
            • Apr 2013
            • 539
            removed ic checked all print connections
            cleaned underside of ic, retinned the print
            refitted ic.
            same as before except i now have .2 volts on o/p pins
            before i had 0v on o/p
            enable pin has 3.2v on it
            im going to try another ic in case i used too much heat to flow the solder.
            (clutching at straws)
            i preheat the board underneath to approx 200 deg
            then fit chip
            then use s/station to melt solder and wait for flow
            i suppose something else on panel could have been damaged due to original faulty psu
            putting out more than 3v this is why the 5v zener failed
            • lotas
              • Jan 2016
              • 4968
              • Russia
              #26
              See the diagram for what else the standbay + 3.5v_ST bus powers
              • jimbofz
                • Apr 2013
                • 539
                #27
                some progress .
                i supplied 1.5v to o/p and tv works ok
                so as Lotas said chip must not be seated correctly
                this has been my first time working with these sub minature ics
                i suppose practice makes perfect .ive ordered a couple more of this ic
                and im ordering another type of liquid flux
                ive used the same flux for years without any problems
                it wont do any harm to try another flux
                i will report back with results
                • lotas
                  • Jan 2016
                  • 4968
                  • Russia
                  #28
                  You may also have suffered a MICOM (standby controller and it contains the firmware that controls it) 33 pin. gives the command to turn on just on it.
                  • jimbofz
                    • Apr 2013
                    • 539
                    #29
                    thanks for advice ,
                    but as tv works fine with 1.5v injected from bench psu
                    i assume ic is not making good contact ,
                    or i may have damaged it with too much heat
                    i have ordered another
                    • jimbofz
                      • Apr 2013
                      • 539
                      #30
                      while i am waiting for chips to arrive ive been running tv with a LM317 as shown in pic
                      i know the original chip is rated at 3 amp and the lm317 is 1.5 amp
                      the 2 resistor values allow correct 1.5v o/p
                      i just wanted to confirm tv had no other problems ,and it seems fine.
                      the temporary reg only gets slightly warm
                      dont understand why pic is upside down?
                      • devsigner
                        identify capacitor for MacBook Pro with rare logic board 820-02037-06
                        by devsigner
                        Hi
                        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
                        resistance tests show a rising resistance value, indicating a capacitor.
                        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
                        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
                        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
                        11-28-2025, 01:39 PM
                      • thesame
                        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                        by thesame
                        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                        02-27-2024, 04:31 AM
                      • silver60618
                        Lenovo Legion 7 - Help Identify IC
                        by silver60618
                        Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                        I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                        Any help would be appreciated...
                        07-02-2025, 12:16 PM
                      • chth96
                        How can I identify varistor which have been blew up?
                        by chth96
                        I mistakely pluged 100v japanese retro game console to 220v outlet.
                        So It seems that glass fuse and varistor have been blew up.
                        I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                        Is there any way to identify varistor type in my sega saturn PSU?
                        Any reply would be appreciated.
                        EDIT:
                        It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                        11-26-2023, 08:52 AM
                        BL0202C BL0202B BL0200C Datasheet
                        The BL0202C BL0202B BL0200C are 2ch output LED driver IC for LED backlight, and it can do dimming to 0.02% by external PWM signal.
                        This IC realizes a high efficiency by the boost convertor control that absorbs variability on VF.
                        The product easily achieves high cost-performance LED drive system with few external components and enhanced protection functions.
                        Features and Benefit
                        Boost Convertor
                        ● Current-Mode type PWM Control
                        ● PWM frequency is 100 kHz or 200 kHz
                        ● Maximum On Duty is 90%
                        LED current...
                        10-07-2024, 04:48 AM
